I have flashed following software to my newly acquired Sonoff Zigbee 3.0 USB Dongle Plus:
Got SUCCESS at the end, so then moved to the next step. Inserted into RPI4 with HA. Under Integrations I found my device, but after hitting Configure button I got some error message
Installed Zigbee2MQTT and set it up, however I was not able to discover any devices. Suspect that something went wrong during configuration and that device is not working properly as a result. When can I try to do? Already restarted HA, then took out Sonoff Zigbee device, deleted integration, inserted dongle back and rediscovered, but ended with the same config error message.
By the way, in device list I do see device:
Texas Instruments CC1352/CC2652, Z-Stack 3.30+ (build 20220219)
When I checked log, I see following message:
and following text:
Logger: homeassistant.components.zha.core.gateway
Source: components/zha/core/gateway.py:152
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 1:31:05 PM (289 occurrences)
Last logged: 9:02:16 PM
Couldn't start ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2 coordinator
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 530, in _skip_bootloader
result = await responses.get()
File "/usr/local/lib/python3.9/asyncio/queues.py", line 166, in get
await getter
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 152, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.9/site-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 152, in startup
return await self._startup(
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/zigbee/application.py", line 165, in _startup
await znp.connect()
File "/usr/local/lib/python3.9/site-packages/zigpy_znp/api.py", line 572, in connect
self.capabilities = (await self._skip_bootloader()).Capabilities
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.9/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
