SONOFF ZigBee 3.0 USB Dongle Plus not connected when reboot
Hi there,
I’m running the latest version of HA on a Virtualbox VM (Win 11 NUC). After successfully installing the SONOFF ZigBee 3.0 USB Dongle Plus with Zigbee2MQTT and Mosquitto, I have the same problem every time I need to reboot the NUC, of course I save and close the VM first.
When I restart the VM, the SONOFF ZigBee dongle is not visible in the HA hardware list.
When I unplug the dongle and plug it back in, it works.
Is there another solution? Unplug/plug seems a bit archaic.
Thanks in advance.
Sorry not much help here but im having the same issue with the same setup. Hopefully someone can help.
I have the same problem with ZHA, please help.
I’ve been told that VMWare Virtual Machine doesn’t havethis issue.
I’ll try to create a VM on VMWare and let you know if that works.
I believe I have seen similar behavior under docker on Ubuntu host and then in docker under Ubuntu under Proxmox. The MCU in the zigbee dongle does not seem to end up in a ‘good’ state on reboot. I think is a hit and miss, but more of the time the reconnect after reboot will fail. I noted that Zigbee2MQTT just released new firmware for this chip set, I have as yet tried it and also not sure all the issues it addresses:
user@docker-01:~$ tio -L
/dev/serial/by-id/usb-1a86_TubesZB_971207DO-if00-port0
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_5cf90e3b6229ec119a9a6d7840c9ce8d-if00-port0
Finally I switched to VMWare Workstation Player 17. There is no need to disconnect and reconnect the Sonoff Zigbee dongle after VM boot.
A step by step is avaialable to setup an automatic connexion of the dongle: Installing Home Assistant on VMWare Workstation 17 - #8 by FriedCheese
You may have already moved on to greener pastures with this issue, but I found a solution that at least in my case is working. I played around with it a bit and I found if I disabled and re-enabled the device in windows, it would act like I had unplugged it and plugged it back in. I’m not much of a coder / scripter, so figuring out how to get it to automate was a bit annoying, but I did come up with a PowerShell script I can run via task scheduler after home assistant starts; essentially handing off the USB driver to home assistant. It’s late tonight, but if anybody else is still having this problem / if there’s still interest, I’d be happy to make a tutorial.
I had the same problem, I wrote a small script in Autoit, you have to install Devcon too.
Just put the au3 file in the windows start folder.
#RequireAdmin
If Not IsAdmin() Then
MsgBox(16, “Erreur”, “Have to be admin !”)
Exit
EndIf
Sleep(30000)
; Disable USB Silicon Labs ports
RunWait(‘devcon disable “USB\VID_10C4&PID_EA60”’)
; wait 3 secondes
Sleep(3000)
; Enable USB Silicon Labs ports
RunWait(‘devcon enable “USB\VID_10C4&PID_EA60”’)
MsgBox(64, “”, “Port Restarted”)
A bit late to this thread, I am having this issue. Can you share your script and how you scheduled it? Thanks
