i have connected a Sonoff Zigbee 3.0 USB Dongle Plus Zigbee Home Automation Stick to my Homeassistant Mini PC. If I don’t go to configure the discovered device and don’t configure the device, everything works. The stick is recognized. When I now go to configure I get the following error message.
“Error testing USB device”
The following note is in the LOG.
Logger: homeassistant.util.loop
Quelle: util/loop.py:136
Erstmals aufgetreten: 10:30:18 (10 Vorkommnisse)
Zuletzt protokolliert: 10:30:18
Detected blocking call to glob with args ('/dev/ttyACM*',) inside the event loop by integration 'zha' at homeassistant/components/zha/radio_manager.py, line 221: probe_result = await radio.controller.probe(dev_config) (offender: /usr/local/lib/python3.12/site-packages/serial/tools/list_ports_linux.py, line 95: devices.extend(glob.glob('/dev/ttyACM*')) # usb-serial with CDC-ACM profile), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22 For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#glob Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle return await handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware response = await handler(request) File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle result = await handler(request, **request.match_info) File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin return await func(self, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post return await super().post(request, flow_id) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper return await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post result = await self._flow_mgr.async_configure(flow_id, data) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure result = await self._async_configure(flow_id, user_input) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure result = await self._async_handle_step( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step result: _FlowResultT = await getattr(flow, method)(user_input) File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 553, in async_step_confirm probe_result = await self._radio_mgr.detect_radio_type() File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 221, in detect_radio_type probe_result = await radio.controller.probe(dev_config)
Detected blocking call to glob with args ('/dev/ttyAMA*',) inside the event loop by integration 'zha' at homeassistant/components/zha/radio_manager.py, line 221: probe_result = await radio.controller.probe(dev_config) (offender: /usr/local/lib/python3.12/site-packages/serial/tools/list_ports_linux.py, line 96: devices.extend(glob.glob('/dev/ttyAMA*')) # ARM internal port (raspi)), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22 For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#glob Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle return await handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware response = await handler(request) File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle result = await handler(request, **request.match_info) File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin return await func(self, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post return await super().post(request, flow_id) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper return await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post result = await self._flow_mgr.async_configure(flow_id, data) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure result = await self._async_configure(flow_id, user_input) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure result = await self._async_handle_step( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step result: _FlowResultT = await getattr(flow, method)(user_input) File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 553, in async_step_confirm probe_result = await self._radio_mgr.detect_radio_type() File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 221, in detect_radio_type probe_result = await radio.controller.probe(dev_config)
Detected blocking call to glob with args ('/dev/rfcomm*',) inside the event loop by integration 'zha' at homeassistant/components/zha/radio_manager.py, line 221: probe_result = await radio.controller.probe(dev_config) (offender: /usr/local/lib/python3.12/site-packages/serial/tools/list_ports_linux.py, line 97: devices.extend(glob.glob('/dev/rfcomm*')) # BT serial devices), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22 For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#glob Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle return await handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware response = await handler(request) File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle result = await handler(request, **request.match_info) File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin return await func(self, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post return await super().post(request, flow_id) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper return await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post result = await self._flow_mgr.async_configure(flow_id, data) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure result = await self._async_configure(flow_id, user_input) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure result = await self._async_handle_step( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step result: _FlowResultT = await getattr(flow, method)(user_input) File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 553, in async_step_confirm probe_result = await self._radio_mgr.detect_radio_type() File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 221, in detect_radio_type probe_result = await radio.controller.probe(dev_config)
Detected blocking call to glob with args ('/dev/ttyAP*',) inside the event loop by integration 'zha' at homeassistant/components/zha/radio_manager.py, line 221: probe_result = await radio.controller.probe(dev_config) (offender: /usr/local/lib/python3.12/site-packages/serial/tools/list_ports_linux.py, line 98: devices.extend(glob.glob('/dev/ttyAP*')) # Advantech multi-port serial controllers), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22 For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#glob Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle return await handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware response = await handler(request) File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle result = await handler(request, **request.match_info) File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin return await func(self, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post return await super().post(request, flow_id) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper return await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post result = await self._flow_mgr.async_configure(flow_id, data) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure result = await self._async_configure(flow_id, user_input) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure result = await self._async_handle_step( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step result: _FlowResultT = await getattr(flow, method)(user_input) File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 553, in async_step_confirm probe_result = await self._radio_mgr.detect_radio_type() File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 221, in detect_radio_type probe_result = await radio.controller.probe(dev_config)
Detected blocking call to open with args ('/sys/devices/pnp0/00:03/id',) inside the event loop by integration 'zha' at homeassistant/components/zha/radio_manager.py, line 221: probe_result = await radio.controller.probe(dev_config) (offender: /usr/local/lib/python3.12/site-packages/serial/tools/list_ports_linux.py, line 84: with open(os.path.join(*args)) as f:), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22 For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete self.run_forever() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever self._run_once() File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once handle._run() File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run self._context.run(self._callback, *self._args) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request resp = await request_handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle return await handler(request) File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware return await handler(request) File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware response = await handler(request) File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle result = await handler(request, **request.match_info) File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin return await func(self, request, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post return await super().post(request, flow_id) File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper return await method(view, request, data, *args, **kwargs) File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post result = await self._flow_mgr.async_configure(flow_id, data) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 370, in async_configure result = await self._async_configure(flow_id, user_input) File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 417, in _async_configure result = await self._async_handle_step( File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 520, in _async_handle_step result: _FlowResultT = await getattr(flow, method)(user_input) File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 553, in async_step_confirm probe_result = await self._radio_mgr.detect_radio_type() File "/usr/src/homeassistant/homeassistant/components/zha/radio_manager.py", line 221, in detect_radio_type probe_result = await radio.controller.probe(dev_config)
What can I do? Do I have to create a bug report? Is the stick faulty? I would be happy to receive support.
Greetings from Stefan Harbich
