Zigbee info
IEEE: b4:35:22:ff:fe:03:11:1b
Nwk: 0x0000
Device Type: Coordinator
LQI: 255
RSSI: Unknown
Last seen: 2024-09-16T06:26:08
Power source: Mains
I happened to come across a post talking about using a EmberZNet firmware, is this something I should be doing?
If not, is the Firmware I have the latest and most stable to use?
That version is quite old. There is newer firmware available on the Sonoff website. On the other hand, if your Zigbee mesh is working, no need to update.
That was clear from the firmware version.
Since you are using ZHA, i don’t think it makes much difference if you upgrade or not. Should you want to use Zigbee2MQTT, it is advisable to upgrade to firmware 7.4.x so you can use the ember
