Sonoff Zigbee Dongle-e with router FW discovered as the existing coordinator in ZHA
Hi everyone, I’ll try to explain the issue I ran into, for which I couldn’t find any solution online, but maybe someone else has already faced it.
I created a ZHA network using the Sonoff device in object as the coordinator, but for weeks I experienced continuous disconnections of Aqara sensors. After doing some research and finding very positive reviews, I bought an SLZB-06 and used ZHA’s migration feature to avoid having to rejoin all the sensors.
To avoid leaving the Sonoff unused and to strengthen the network, I followed the procedure to replace the Sonoff firmware from coordinator to router. The procedure always completed successfully using different firmware versions, but when I enable ZHA to join new devices and try to connect the Sonoff as a repeater, it shows up as a “new device” to be paired — but the device that appears seems to be the same SLZB coordinator.
Reading around, I understood that the migration might transfer some information related to the old coordinator (PAN ID?), but I thought this information would be cleared when flashing the firmware.
Can someone of you help me understand what’s going on and if/how this can be fixed?
Many thanks in advance for your support
Alberto
The ieee address of the SLZB-06 sonoff stick was changed to match the prior sonoff stick during the migration.
You now have two devices with the same ieee address and it is confusing ZHA.
I’ve seen conflicting reports, I’m not sure if the Dongle-E ieee address can be changed in the router firmware.
Changing ieee is easy with a Dongle-P router, but I haven’t had the need to try changing it on a Dongle-E router.
Hi, thanks for your reply.
Do you have any suggestion/link to follow about the IEEE address changing procedure for Dongle-P to understand if it’s applicable also on Dongle-E?
One additional info I missed on my first post: I actually have a second zigbee network based on zigbee2mqtt with a second SLZB as coordinator, I don’t know if this could simplify the IEEE address change process (joining the Dongle-E on the z2m network and changing the address via z2m funcionalities, if there are any existing one).
Alberto
It’s not, the utilities are entirely different. TI chipsets/firmware have always been easier to manage in this regard.
Upgrades to the ezsp coordinator firmware removed most of the ezsp restrictions for coordinators, but I don’t know if any of that functionality ever made it to the router firmware.
z2m doesn’t have any special magic for this.
I answered an identical question yesterday & it seems the question keeps popping up every day because there’s no warning about this when you migrate. The below is my understanding of how it works.
Basically, a zigbee coordinator has 2 IEEE slots available:
Slot 1 is written in the factory and can never be changed.
Slot 2 is empty (null) by default & can be populated once. After that, you cannot change it.
Migration process copies Slot 1 IEEE address from your old coordinator, then pastes it into Slot 2 of your new coordinator.
This means that the original IEEE address exists on both devices & that only one of them can ever be present in your mesh. Otherwise, you’ll get conflicts (even if you managed to populate Slot 2 on your old device).
Essentially, this means you cannot use the old Sonoff in your mesh any more. I suggest you sell it online or give it to a friend so at least it doesn’t go in the trash.
I found the solution!
Using the correct keywords in google I found this link:
https://www.zigbee2mqtt.io/guide/adapters/flashing/copy_ieeaddr.html
that have as main objective the process to copy the IEEE address when migrating from an old to a new coordinator seamlessly, but, in essence, provides for the IEEE overwriting process.
I managed to reach the goal using the XZG Multi-tool, but:
  1. the tool correctly handles the ZBDongle-E only with the Coordinator fw, so I had to re-flash the dongle with the last coordinator fw (8.0.2)
  2. once connected the dongle in BSL i launched the IEEE read function
  3. I wrote the same IEEE in the “New IEEE” field changing only the last two digits (the ZBDongle-E requires the “Force” option)*
  4. reset the device and re-flashed the dongle with the last router fw
  5. put the ZHA again in joining mode and… et voilà!! Finally the ZBDongle-E is back alive as router!!
*far as I understood the change of IEEE for ZBDongle-E using “Force” option seems to be a “once only” solution
Hope this will help for others who find themselves in the same situation.
Ciao!
A
Thank you so much @asjbm, this worked for me!
I spent hours trying various “solutions” and suggestions to change the IEEE on my Sonoff ZDongle-E router. Some were quite complicated, but none worked. I was about to toss it in the trash when I came across this post. XZG Multi-Tool did the job and it was simple and fast too.
