Sonoff Zigbee Dongle-e with router FW discovered as the existing coordinator in ZHA
I found the solution!
Using the correct keywords in google I found this link:
https://www.zigbee2mqtt.io/guide/adapters/flashing/copy_ieeaddr.html
that have as main objective the process to copy the IEEE address when migrating from an old to a new coordinator seamlessly, but, in essence, provides for the IEEE overwriting process.
I managed to reach the goal using the XZG Multi-tool, but:
  1. the tool correctly handles the ZBDongle-E only with the Coordinator fw, so I had to re-flash the dongle with the last coordinator fw (8.0.2)
  2. once connected the dongle in BSL i launched the IEEE read function
  3. I wrote the same IEEE in the “New IEEE” field changing only the last two digits (the ZBDongle-E requires the “Force” option)*
  4. reset the device and re-flashed the dongle with the last router fw
  5. put the ZHA again in joining mode and… et voilà!! Finally the ZBDongle-E is back alive as router!!
*far as I understood the change of IEEE for ZBDongle-E using “Force” option seems to be a “once only” solution
Hope this will help for others who find themselves in the same situation.
Ciao!
A
