Hey guys,
I think I know the answer, but maybe need your confirmation.
I’m struggling to get my Sonoff Dongle-E to work again after stupidly flashing it with the Multiprotocol firmware after I had it working with the latest Zigbee 7.4.3.0.115100 firmware.
This is my current issue, after to reflashing back to 7.4.3.0
[16:56:22] INFO: Preparing to start...
[16:56:22] INFO: Socat not enabled
[16:56:23] INFO: Starting Zigbee2MQTT...
[2024-06-11 16:56:25] info: z2m: Logging to console, file (filename: log.log)
[2024-06-11 16:56:25] info: z2m: Starting Zigbee2MQTT version 1.38.0 (commit #unknown)
[2024-06-11 16:56:25] info: z2m: Starting zigbee-herdsman (0.49.2)
[2024-06-11 16:56:25] info: zh:ember: Using default stack config.
[2024-06-11 16:56:25] info: zh:ember: ======== Ember Adapter Starting ========
[2024-06-11 16:56:25] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-06-11 16:56:25] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-11 16:56:25] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-06-11 16:56:25] info: zh:ember:uart:ash: Serial port opened
[2024-06-11 16:56:25] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-06-11 16:56:28] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-11 16:56:28] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-06-11 16:56:30] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-11 16:56:30] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-06-11 16:56:33] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-11 16:56:33] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-06-11 16:56:35] info: zh:ember:uart:ash: ======== ASH NCP reset ========
[2024-06-11 16:56:35] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-06-11 16:56:38] error: z2m: Error while starting zigbee-herdsman
[2024-06-11 16:56:38] error: z2m: Failed to start zigbee
[2024-06-11 16:56:38] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-06-11 16:56:38] error: z2m: Exiting...
[2024-06-11 16:56:38] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:850:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2683:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:62:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Seems to be failing at the ASH start up.
Is there a way back, or have I bricked my brand new dongle?
