Good day
I am running zigbee2mqtt inside a docker compose file (below) with this configuration (also below). I installed the latest firmware from Z-Stack-firmware/coordinator/Z-Stack_3.x.0/bin at master · Koenkk/Z-Stack-firmware · GitHub (the launchpad firmware)
I proceeded to flash the dongle with the TI tool and subsequently also using the Python method. In both instances the dongle is not seen by the Zigbee2Mqtt web interface, but, Home Assistant does see the dongle. But, I dont want to use ZHA, and from what I remember you then have to just ignore that message in Home Assistant. (even when I click on the “configure” button to see what happens, I get the message"Failed to probe the USB device")
Docker Compose
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/homeassistant/config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
mosquitto:
depends_on:
- homeassistant
container_name: mosquitto
image: eclipse-mosquitto:latest
volumes:
- /opt/homeassistant/mosquitto/config:/mosquitto/config/
- /opt/homeassistant/mosquitto/log:/mosquitto/log/
- /opt/homeassistant/mosquitto/data:/mosquitto/data/
ports:
- 1883:1883
- 9001:9001
zigbee2mqtt:
container_name: zigbee2mqtt
depends_on:
- mosquitto
image: koenkk/zigbee2mqtt
volumes:
- /opt/homeassistant/zigbee2mqtt/data:/app/data
- /run/udev:/run/udev:ro
ports:
- 8080:8080
devices:
- /dev/ttyUSB0:/dev/ttyACM0
privileged: true
Zigbee2Mqtt config
homeassistant: true
permit_join: true
frontend: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://mosquitto
user: hauser
password: testpass
serial:
port: /dev/ttyACM0
advanced:
log_level: debug
ls -l /dev/serial/by-id/
Output
lrwxrwxrwx 1 root root 13 Mar 6 10:59 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7ee499da85c9eb119c4b8f4f1d69213e-if00-port0 -> ../../ttyUSB0
ls -l /dev/ttyUSB0
Output
crw-rw---- 1 root dialout 188, 0 Mar 6 10:59 /dev/ttyUSB0
I did test my permissions with test -w /dev/ttyUSB0 && echo success || echo failure
and it all is good.
My setup is as follows:
- Intel NUC
- Docker version 20.10.12, build 20.10.12-0ubuntu4
- docker-compose version 1.29.2, build unknown
I will appreciate any assistance. Let me know if I need to pull logs or the like. Here are some logs but it doesnt look like there are any errors or warnings in there.
Using '/app/data' as data directory
Zigbee2MQTT:debug 2023-03-06 08:58:28: Can't load state from file /app/data/state.json (doesn't exist)
Zigbee2MQTT:info 2023-03-06 08:58:28: Logging to console and directory: '/app/data/log/2023-03-06.08-58-28' filename: log.txt
Zigbee2MQTT:debug 2023-03-06 08:58:28: Removing old log directory '/app/data/log/2023-03-06.08-17-10'
Zigbee2MQTT:info 2023-03-06 08:58:29: Starting Zigbee2MQTT version 1.30.2 (commit #cdf62ea)
Zigbee2MQTT:info 2023-03-06 08:58:29: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:debug 2023-03-06 08:58:29: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyACM0"}}'
Zigbee2MQTT:info 2023-03-06 08:58:45: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-03-06 08:58:45: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:debug 2023-03-06 08:58:45: Zigbee network parameters: {"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754}
Zigbee2MQTT:info 2023-03-06 08:58:45: Currently 0 devices are joined:
Zigbee2MQTT:warn 2023-03-06 08:58:45: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2023-03-06 08:58:45: Allowing new devices to join.
Zigbee2MQTT:warn 2023-03-06 08:58:45: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2023-03-06 08:58:45: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-03-06 08:58:45: Connecting to MQTT server at mqtt://mosquitto
Zigbee2MQTT:debug 2023-03-06 08:58:45: Using MQTT login with username: hauser
Zigbee2MQTT:info 2023-03-06 08:58:46: Connected to MQTT server
Zigbee2MQTT:info 2023-03-06 08:58:46: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-03-06 08:58:46: Started frontend on port 0.0.0.0:8080
Zigbee2MQTT:debug 2023-03-06 08:58:46: Received MQTT message on 'zigbee2mqtt/bridge/config' with data '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754},"permit_join":true,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-06 08:58:46: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754},"permit_join":true,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-06 08:58:46: Zigbee2MQTT started!
Zigbee2MQTT:error 2023-03-06 08:59:32: Adapter disconnected, stopping
Zigbee2MQTT:debug 2023-03-06 08:59:32: Saving state to file /app/data/state.json
Zigbee2MQTT:info 2023-03-06 08:59:32: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'offline'
Zigbee2MQTT:info 2023-03-06 08:59:32: Disconnecting from MQTT server
Zigbee2MQTT:info 2023-03-06 08:59:32: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2023-03-06 08:59:32: Failed to stop Zigbee2MQTT
Zigbee2MQTT:debug 2023-03-06 08:59:59: Loaded state from file /app/data/state.json
Zigbee2MQTT:info 2023-03-06 08:59:59: Logging to console and directory: '/app/data/log/2023-03-06.08-59-59' filename: log.txt
Zigbee2MQTT:debug 2023-03-06 08:59:59: Removing old log directory '/app/data/log/2023-03-06.08-17-45'
Zigbee2MQTT:info 2023-03-06 08:59:59: Starting Zigbee2MQTT version 1.30.2 (commit #cdf62ea)
Zigbee2MQTT:info 2023-03-06 08:59:59: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:debug 2023-03-06 08:59:59: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyACM0"}}'
Zigbee2MQTT:info 2023-03-06 09:00:04: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-03-06 09:00:04: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:debug 2023-03-06 09:00:04: Zigbee network parameters: {"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754}
Zigbee2MQTT:info 2023-03-06 09:00:04: Currently 0 devices are joined:
Zigbee2MQTT:warn 2023-03-06 09:00:04: `permit_join` set to `true` in configuration.yaml.
Zigbee2MQTT:warn 2023-03-06 09:00:04: Allowing new devices to join.
Zigbee2MQTT:warn 2023-03-06 09:00:04: Set `permit_join` to `false` once you joined all devices.
Zigbee2MQTT:info 2023-03-06 09:00:04: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-03-06 09:00:05: Connecting to MQTT server at mqtt://mosquitto
Zigbee2MQTT:debug 2023-03-06 09:00:05: Using MQTT login with username: hauser
Zigbee2MQTT:info 2023-03-06 09:00:05: Connected to MQTT server
Zigbee2MQTT:info 2023-03-06 09:00:05: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-03-06 09:00:05: Started frontend on port 0.0.0.0:8080
Zigbee2MQTT:debug 2023-03-06 09:00:05: Received MQTT message on 'zigbee2mqtt/bridge/config' with data '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754},"permit_join":true,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-06 09:00:05: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0024c0a835","panID":6754},"permit_join":true,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-06 09:00:05: Zigbee2MQTT started!
I passed through the Zigbee USB Dongle using the /dev/tty as well as /dev/serial/by-id methods. I also changed ACM0 in Zigbee2Mqtt to USB0 but this also did not make a difference.
