Sonoff Zigbee Dongle with ZHA nothing can connect to it
This the my first attempt to use any zigbee USB dongle so I am not sure what I might be doing wrong.
I have the sonoff zigbee plus e (CH9102F+MG21).I am running home-assistant core in Unraid using Docker. I pass the sonoff dongle as device by id
--device /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220816110612-if00.
Home assistant properly detects it, I configure it all fine and it looks like it’s working but I nothing can connect to it.
I have tried aqara temperature and humidity sensor, ikea motion sensor, ikea simple switch, tuya zigbee socket.
Can someone please help me figure out what I am doing wrong?
Update
I tried with zigbee2mqtt and with it they work great. However, I would prefer to have the integration natively in HA if possible
Same here. I’m searching for a fix too.
Have you forwarded the usb port i.e. in the docker-compose.yaml:
    devices:
      - /dev/ttyUSB0:/dev/ttyUSB0
See Zigbee Home Automation - Home Assistant
Be sure to upgrade firmware and follow this to rule out interference → https://github.com/zigpy/zigpy/wiki/Generic-best-practice-tips-on-improving-Zigbee-network-range-and-general-stability
