Sonoff ZigBee Mini Smart Switch can’t be used with a momentary switch?
The documentation says these ZBMINI2 modules can’t be used with momentary switches, is that true? Does a pulse not even get sent through?
I did a bit of digging about here and on Reddit and there was something about this working if it’s the no-neutral module.
Any help appreciated. Thx
Hi omara500,
Are you using home Assistant?
Yes I am, on a raspberry pi 5
Then the switch talks to Home Assistant, not the switched entity. So yes it will work. You tell HA what you want to do via the button and HA affects the entity.
