Sonos Automation - Scenes (Multiple State Adjustments)
Dear All
A new user here, pleased to meet you! I’ve been playing around a bit with Home Assistant now for a while but still trying to master it as much as possible. Having a good code editor helps luckily.
I’m currently a bit stuck with an automation that I’m trying to set-up; or rather tidy up as I like to keep my automations as small as possible. This is why I was looking into scenes. At the moment I have a rather simple automation that will open up the blinds in the living room and the kitchen and in turn will also start playing the Sonos in the kitchen. The automation for now is as follows:
- id: morning_routine_winter_weekdays
  alias: Morning Routines for Winter Weekdays.
  - at: "07:30:00"
    platform: time
  - data:
      entity_id:
      - cover.living__groot_raam
      - cover.living__klein_raam
      - cover.keuken__groot_raam
    service: cover.open_cover
  - service: media_player.select_source
      entity_id: media_player.keuken
      source: "Joe"
  - service: media_player.volume_set
      volume_level: 0.07
  - service: media_player.turn_on
What I am trying to achieve now is to change this code towards something as follows:
  - at: "07:30:00"
    platform: time
  - data:
      entity_id:
  - service: scene.turn_on
      entity_id: scene.scene_morning_winter
My scenes file looks as follows:
- name: scene_morning_winter
  entities:
    light.huiskamer:
      state: on
      xy_color: [0.504, 0.412]
      brightness: 254
    media_player.keuken:
      state: playing
      volume_level: 0.07
      source: "Joe"
Interestingly enough my Sonos does start playing at the correct time; however my volume does not get set and the Sonos Favorite does not get selected. It seems that in a scene I’m only able to change the state of 1 item for a media_player component.
Does anyone have any idea what could cause this and if it’s even possible to control the Sonos in a scenes file? I’ve looked around on the community but haven’t really seen an answer towards this question before.
Thanks a lot for the help!
Kind Regards
Bryan
I don’t use scene but script instead.
@EGO01
Thanks for your input. I’ve just had a look at scripts in Home Assistant and indeed. Very powerful functionality which actually made it possible for me to tidy up my automations a lot. I basically changed it to the following now (Thought I’d share):
Automations File
 - id: automation_morning_weekdays_winter
  alias: Automation - Morning Weekdays - Winter
  - at: "07:30:00"
    platform: time
  - service: script.turn_on
      entity_id:
      - script.script_open_all_covers
      - script.script_sonos_morning_joe
      - script.script_livingroom_bright
Script File
script_open_all_covers:
  sequence:
    - service: cover.open_cover
        entity_id:
script_sonos_morning_joe:
  sequence:
        source: "Joe"
        volume_level: 0.05
script_livingroom_bright:
  sequence:
        entity_id: scene.scene_livingroom_bright
Scenes File
- name: scene_livingroom_bright
  entities:
    light.huiskamer:
      state: on
      brightness: 254
Thanks a lot!
