When using the media player in automations I commonly select the content to play from the Sonos favorites. All of them show except for 1. Interestingly, Sonos categorizes this as “Other” whereas every other one is categorized in a standard way (like Station, Playlist, Album, Song). When using media player I can see how to select the standard Favorite types, but cannot find “Other”. Is there something that I am missing or is this a needed enhancement to the service?
Thank you for the idea here! I was questioning if this would help, as I see my other favorites. But I did find it disables and flipped the switch. It did not make it appear. However, what I did find is that when looking at the entity I found all of the IDs listed, including the one that is not showing. So I just used that ID in my automation and it worked! So… thank you for the tip that helped me find the solution.
