I’ve just spent several days trying to find out why my Hassio (rPi) Sonos integration does not appear to discover any of my speakers. I was pretty convinced it was a networking problem (I have Ubquiti), but it’s not.
It turns out that there was something in my Sonos favourites list that was causing the integration to not start correctly. Clearing pretty much everything from my favourites list did the job. Everything is sweetness and light now.
I’ll add what appears to be the relevant section of the log below. If anyone else is having problems, check the log for similarities. I can provide the full config and log if required.
I hope this saves someone else a few hours of anguish.
Rgds
2022-11-21 13:50:36.603 DEBUG (MainThread) [homeassistant.components.sonos] Adding discovery job
2022-11-21 13:50:36.970 DEBUG (SyncWorker_7) [homeassistant.components.sonos] Adding new speaker: {'zone_name': 'Lounge', 'player_icon': '/img/icon-S6.png', 'uid': 'RINCON_5CAAFD09B3C001400', 'serial_number': '5C-AA-FD-09-B3-C0:4', 'software_version': '70.3-35070', 'hardware_version': '1.13.1.7-2.2', 'model_number': 'S6', 'model_name': 'Sonos Play:5', 'display_version': '14.19', 'mac_address': '5C-AA-FD-09-B3-C0'}
2022-11-21 13:50:37.094 DEBUG (SyncWorker_7) [homeassistant.components.sonos.alarms] Updating processed event 4 from <SoCo object at ip 192.168.1.27> (was None)
2022-11-21 13:50:37.316 DEBUG (SyncWorker_7) [homeassistant.components.sonos.favorites] Processing favorites update_id 17 for <SoCo object at ip 192.168.1.27> (was: None)
2022-11-21 13:50:37.515 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Sonos for sonos
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/sonos/__init__.py", line 147, in async_setup_entry
await manager.setup_platforms_and_discovery()
File "/usr/src/homeassistant/homeassistant/components/sonos/__init__.py", line 407, in setup_platforms_and_discovery
await self.hass.async_add_executor_job(self._poll_manual_hosts)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/sonos/__init__.py", line 290, in _poll_manual_hosts
self._create_visible_speakers(ip_addr)
File "/usr/src/homeassistant/homeassistant/components/sonos/__init__.py", line 198, in _create_visible_speakers
self._add_speaker(zone)
File "/usr/src/homeassistant/homeassistant/components/sonos/__init__.py", line 244, in _add_speaker
new_coordinator.setup(soco)
File "/usr/src/homeassistant/homeassistant/components/sonos/favorites.py", line 42, in setup
super().setup(soco)
File "/usr/src/homeassistant/homeassistant/components/sonos/household_coordinator.py", line 34, in setup
self.update_cache(soco)
File "/usr/src/homeassistant/homeassistant/components/sonos/helpers.py", line 67, in wrapper
result = funct(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/sonos/favorites.py", line 128, in update_cache
if fav.reference.resources:
File "/usr/local/lib/python3.10/site-packages/soco/data_structures.py", line 983, in reference
ref = _FROM_DIDL_STRING_FUNCTION(getattr(self, "resource_meta_data"))[0]
File "/usr/local/lib/python3.10/site-packages/soco/data_structures_entry.py", line 31, in from_didl_string
root = XML.fromstring(string.encode("utf-8"))
File "/usr/local/lib/python3.10/xml/etree/ElementTree.py", line 1343, in XML
return parser.close()
xml.etree.ElementTree.ParseError: no element found: line 1, column 1023
type or paste code here
