Sonos - How to access Music Folder
Hello Community,
I just started with HA and its running quite well. It is installed in with KVM running in OMV.
I would like to access the files stored on my NAS with the SONOS Addon. Unfortunately I does ony offer me the common access to Artist, Albums, Genres etc. the “Folder” is missing (see the picture).
Any possibility to make the “Folder” available?
I tried to add my NAS directly to the Media Folder in HA but I failed, because HA is running in KVA and I didn’t get the Passthrough Filesystem working.
Picture from HA
solved with CIFS Share
Did you get this to work? My setup is - Sonos sees the CIFS share but it is not visible in media browser in HA
Once HA 2023.6.0 drops (or you get the beta now) you will be able to connect HA to your NAS files through the UI.
@sparkydave,
  1. thanks :slight_smile:
  2. if i understand correctly, that would be Sonos → HA → NAS, instead of Sonos → NAS?
Correct.
