Not sure what’s going on, it was broken a few updates then I think it came back on 0.32 but then broke again at 0.32.1/2 (not sure exact versions though).
This is my log:
16-11-13 18:07:39 homeassistant.components.zwave: ZWave network autoheal is enabled.
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bedroom Evening
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Leaving Home
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Movie paused/stopped
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bedroom Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (lower) Day
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Night
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Closet Light Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Movie playing
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Outside Evening
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Nightly Sonos Reset
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Bathroom (upper) Day
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Switch Everything Off
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Coming Home
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Wake Me Up
16-11-13 18:07:40 homeassistant.components.automation: Initialized trigger Closet Light On
16-11-13 18:07:40 homeassistant.components.zwave: Starting ZWave network.
16-11-13 18:07:42 homeassistant.components.http: Serving /api/stream to 40.0.0.78 (auth: True)
16-11-13 18:07:42 homeassistant.components.http: Serving /api/bootstrap to 40.0.0.78 (auth: True)
16-11-13 18:07:43 homeassistant.components.automation: Executing Closet Light Off
16-11-13 18:08:03 homeassistant.components.zwave: Zwave network is ready for use. All awake nodes have been queried. Sleeping nodes will be queried when they awake.
16-11-13 18:08:04 homeassistant.components.zwave: zwave ready after 24 seconds
16-11-13 18:08:04 homeassistant.components.zwave: zwave polling interval set to 60000 ms
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: homekit {'id': '00:17:88:20:49:71', 'c#': '41', 'ff': '1', 'pv': '1.0', 's#': '1', 'ci': '2', 'sf': '1', 'md': 'BSB002', 'host': 'http://40.0.0.20'}
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.15
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.45
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.30
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.48
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.11
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.58
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.86
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.47
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.25
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.37
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.16
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: sonos 40.0.0.13
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: home_assistant ('http://40.0.0.110:8123', '0.32.3', True)
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: mystrom ('BSB002', 'http://40.0.0.20', '00:17:88:20:49:71')
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.25:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.48:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.15:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.47:1400/xml/device_description.xml
16-11-13 18:08:08 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.37:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.11:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.30:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.58:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.100:32469/DeviceDescription.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: DLNA http://40.0.0.13:1400/xml/device_description.xml
16-11-13 18:08:09 homeassistant.components.discovery: Found new service: philips_hue ('Philips hue (40.0.0.20)', 'http://40.0.0.20:80/')
16-11-13 18:08:10 homeassistant.components.discovery: Found new service: plex_mediaserver ('STORAGE', 'https://40.0.0.100:32400')
16-11-13 18:11:31 homeassistant.components.http: Serving / to 40.0.0.74 (auth: False)
16-11-13 18:26:22 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 18:29:11 homeassistant.components.automation: Executing Bathroom (upper) Day
16-11-13 18:29:34 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 18:31:11 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 18:59:27 homeassistant.components.http: Serving /states to 66.102.9.15 (auth: False)
16-11-13 19:07:46 homeassistant.components.updater: Submitted analytics to Home Assistant servers. Information submitted includes {'uuid': 'ff0924595eec4a96978f5455129cc9e3', 'virtualenv': False, 'arch': 'armv7l', 'dev': False, 'os_version': '8', 'version': '0.32.3', 'timezone': 'Europe/Stockholm', 'distribution': 'raspbian', 'docker': False, 'os_name': 'Linux', 'python_version': '3.4.2'}
16-11-13 21:10:26 homeassistant.components.http: Serving /states to 66.102.9.15 (auth: False)
16-11-13 21:27:58 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:31:49 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 21:46:01 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:48:31 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 21:52:15 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 21:58:02 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:00:55 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:03:34 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:03:45 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:07:19 homeassistant.components.http: Serving /api/ to 40.0.0.1 (auth: True)
16-11-13 22:07:23 homeassistant.components.http: Serving /api/config to 40.0.0.1 (auth: True)
16-11-13 22:07:23 homeassistant.components.http: Serving /api/states to 40.0.0.1 (auth: True)
16-11-13 22:07:24 homeassistant.components.http: Serving /api/ios/identify to 40.0.0.1 (auth: True)
16-11-13 22:07:24 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:08:21 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:09:31 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:12:39 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:12:59 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:13:02 homeassistant.components.http: Serving /api/services/device_tracker/see to 40.0.0.1 (auth: True)
16-11-13 22:13:03 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:22:35 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:24:33 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:29:32 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-13 22:30:00 homeassistant.components.automation: Executing Outside Night
16-11-13 22:30:00 homeassistant.components.automation: Executing Bedroom Night
16-11-13 22:30:02 homeassistant.components.http: Serving /api/services/device_tracker/see to 40.0.0.1 (auth: True)
16-11-13 22:30:04 homeassistant.components.http: Serving /api/stream to 40.0.0.1 (auth: True)
16-11-13 22:32:50 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:32:53 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 22:35:33 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 22:47:42 homeassistant.components.http: Serving /states to 40.0.0.60 (auth: False)
16-11-13 22:52:42 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 22:54:03 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 22:56:03 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 22:59:55 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:03:30 homeassistant.components.http: Serving /states to 40.0.0.60 (auth: False)
16-11-13 23:03:45 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:09:05 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 23:09:10 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:17:48 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 23:23:34 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:25:41 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-13 23:25:51 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-13 23:27:30 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-13 23:29:30 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-13 23:41:26 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 00:00:00 homeassistant.components.zwave: ZWave heal running.
16-11-14 00:36:00 homeassistant.components.automation: Executing Bathroom (lower) Night
16-11-14 00:37:19 homeassistant.components.automation: Executing Closet Light Off
16-11-14 00:38:50 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 04:00:00 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:00 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:01 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:01 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:02 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:02 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:03 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:03 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:04 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:04 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:05 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:05 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:06 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:06 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:07 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:07 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:08 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:08 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:09 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:09 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:10 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:10 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:11 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:11 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:12 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:12 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:13 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:13 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:14 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:14 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:15 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:15 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:16 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:16 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:17 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:17 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:18 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:18 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:19 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:19 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:20 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:20 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:21 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:21 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:22 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:22 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:23 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:23 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:24 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:24 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:25 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:25 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:26 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:26 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:27 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:27 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:28 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:28 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:29 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:29 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:30 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:30 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:31 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:31 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:32 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:32 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:33 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:33 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:34 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:34 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:35 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:35 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:36 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:36 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:37 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:37 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:38 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:38 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:39 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:39 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:40 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:40 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:41 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:41 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:42 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:42 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:43 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:43 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:44 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:44 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:45 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:45 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:46 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:46 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:47 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:47 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:48 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:48 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:49 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:49 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:50 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:50 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:51 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:51 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:52 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:52 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:53 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:53 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:54 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:54 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:55 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:55 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:56 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:56 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:57 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:57 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:58 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:58 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 04:00:59 homeassistant.components.automation: Executing Nightly Sonos Reset
16-11-14 04:00:59 homeassistant.core: Unable to find service media_player/sonos_unjoin
16-11-14 05:47:00 homeassistant.components.automation: Executing Bathroom (upper) Night
16-11-14 05:50:37 homeassistant.components.automation: Executing Bathroom (upper) Off
16-11-14 06:30:00 homeassistant.components.automation: Executing Wake Me Up
16-11-14 06:30:06 homeassistant.components.notify.ios: iOS push notification rate limits for iphone: 1 sent, 150 allowed, 0 errors, resets in 18:29:53
16-11-14 07:03:58 homeassistant.components.automation: Executing Bathroom (lower) Day
16-11-14 07:16:49 homeassistant.components.automation: Executing Bathroom (lower) Off
16-11-14 07:17:46 homeassistant.components.automation: Executing Closet Light On
16-11-14 07:18:56 homeassistant.components.automation: Executing Closet Light Off
