Hello, I am not familiar with Sonos and Homeassistant together. I am having some trouble with sonos. It occurs when I play a playlist in Sonos. Does this mean that the source that can be called can only be single songs? Seems weird
> 17-01-07 22:58:46 soco.services: UPnP Error 714 received: Illegal MIME-Type from 10.0.0.31
> Traceback (most recent call last):
> File "C:\Users\alvar\AppData\Roaming\.homeassistant\deps\soco\services.py", line 408, in send_command
> self.handle_upnp_error(response.text)
> File "C:\Users\alvar\AppData\Roaming\.homeassistant\deps\soco\services.py", line 469, in handle_upnp_error
> error_xml=xml_error
> soco.exceptions.SoCoUPnPException: UPnP Error 714 received: Illegal MIME-Type from 10.0.0.31
> 17-01-07 22:59:44 homeassistant.core: Error doing job: Future exception was never retrieved
> File "C:\Users\alvar\AppData\Local\Programs\Python\Python35\lib\concurrent\futures\thread.py", line 55, in run
> result = self.fn(*self.args, **self.kwargs)
> File "C:\Users\alvar\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\core.py", line 1054, in execute_service
> service_handler.func(service_call)
> File "C:\Users\alvar\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\components\media_player\__init__.py", line 381, in select_source_service
> player.select_source(input_source)
> File "C:\Users\alvar\AppData\Local\Programs\Python\Python35\lib\site-packages\homeassistant\components\media_player\sonos.py", line 838, in select_source
> self._player.play_uri(src['uri'], src['meta'], src['title'])
> File "C:\Users\alvar\AppData\Roaming\.homeassistant\deps\soco\core.py", line 104, in inner_function
> return function(self, *args, **kwargs)
> File "C:\Users\alvar\AppData\Roaming\.homeassistant\deps\soco\core.py", line 483, in play_uri
> ('CurrentURIMetaData', meta)
> File "C:\Users\alvar\AppData\Roaming\.homeassistant\deps\soco\services.py", line 181, in _dispatcher
> return self.send_command(action, *args, **kwargs)
> error_xml=xml_error
Any help?
Thank you!
Alvaro
