I have made a script for Sonos speakers for general announcements that snapshots, groups everything together, calls google tts, calculates delay, then restores. It’ll get as far as doing the TTS, but then the script crashes. I can’t tell exactly where, other than it is either in the dynamic delay calculations. Something in the templating…
Script is:
Sonos_group_tts:
alias: Group Sonos Text To Speech
sequence:
- service: media_player.sonos_snapshot
entity_id:
- media_player.family_room
- media_player.kitchen
- service: media_player.sonos_unjoin
entity_id:
- service: media_player.sonos_join
master: media_player.family_room
entity_id:
- service: media_player.volume_set
entity_id:
volume_level: 0.5
- service: tts.google_say
data_template:
entity_id: media_player.family_room
message: "{{ what }}"
- delay:
seconds: 1
- delay: >-
{% set duration = states.media_player[where].attributes.media_duration %}
{% if duration > 0 %}
{% set duration = duration - 1 %}
{% endif %}
{% set seconds = duration % 60 %}
{% set minutes = (duration / 60)|int % 60 %}
{% set hours = (duration / 3600)|int %}
{{ [hours, minutes, seconds]|join(':') }}
- service: media_player.sonos_restore
data_template:
entity_id: "media_player.family_room"
Dev panel tells me only this:
Error doing job: Task exception was never retrieved
File "/usr/src/app/homeassistant/helpers/template.py", line 131, in async_render
return self._compiled.render(kwargs).strip()
File "/usr/local/lib/python3.6/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.6/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.6/site-packages/jinja2/sandbox.py", line 385, in getattr
value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: homeassistant.helpers.template.DomainStates object has no element Undefined
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/src/app/homeassistant/helpers/script.py", line 104, in async_run
delay.async_render(variables))
File "/usr/src/app/homeassistant/helpers/template.py", line 133, in async_render
raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: homeassistant.helpers.template.DomainStates object has no element Undefined
Maybe this is a race condition? Any help would be appreciated. Thanks.
