SONOS TTS Script
I managed to specify a dynamic delay that should be about the duration of the spoken text by the following script. Apparently the initial 1s delay is necessary for the duration in the state to be filled.
alias: Sonos Text To Speech
sequence:
  - service: media_player.sonos_snapshot
    data_template:
      entity_id: "{{ 'media_player.' ~ where }}"
  - service: tts.google_say
    data_template:
      message: "{{ what }}"
  - delay:
      seconds: 1
  - delay: >-
      {% set duration = states.media_player[where].attributes.media_duration %}
      {% if duration > 0 %}
        {% set duration = duration - 1 %}
      {% endif %}
      {% set seconds = duration % 60 %}
      {% set minutes = (duration / 60)|int % 60 %}
      {% set hours = (duration / 3600)|int %}
      {{ [hours, minutes, seconds]|join(':') }}
  - service: media_player.sonos_restore
    data_template:
Hope that helps. :slight_smile:
@tleilax Awesome! Thanks! :slight_smile:
GREAT WORK!! Is there a way to set configurations for “sonos_restore”? I find the sliding volume to the original state annoyingly slow.
/Tonkin
By the way: Im having tons of fun with this:
curl -X POST -H "x-ha-access: {{mysecretcode}}" \
       -H "Content-Type: application/json" \
       -d '{"where": "livingroom", "what": "Hello my friend"}' \
       http://192.168.1.3:8123/api/services/script/say
:smiley:
Tonkin
does this mean you are setting your where variable to “.living_room” with the leading period? How did you manage to pass the variable into the set statement?
Okay, I was able to figure out the nuances here. I think I’ve got it. I’m using a similar format to create a recursive script to transition lights that don’t support it natively.
I might be stupid but I can’t get it to work. When i call the test_ttl script nothing happens for me.
configuration.yaml
script: !include_dir_merge_named includes/scripts
scripts/sonos_tts.yaml
sonos_tts:
  sequence:
      data_template:
      data_template:
    - delay:
        seconds: 1
    - delay: >-
        {% endif %}
        "{{ [hours, minutes, seconds]|join(':') }}"
      data_template:
scripts/test_tts.yaml
test_tts:
  alias: Test for TTS
  sequence:
    - service: script.turn_on
      entity_id: script.say
        variables:
          where: 'media_player.kitchen'
          what: 'Test.'
@christian.ek The new version only expects where: ‘kitchen’, since media_player. is already part of the script and templates.
Found the error… I renamed it sonos_tts but when calling the script i used script.say
Thanks for the great script! I added some features to really make sure that the message is played only in the specific media player (unjoin first) and not to the whole group that it is connected to. On top of that I changed the volume so it wouldnt use the same volume as the speaker was set to.
    # > SONOS TTS
  say:
    alias: SONOS TTS
    sequence:
        data_template:
          with_group: yes
      - service: media_player.sonos_unjoin
        data_template:
      - service: media_player.volume_set
        data_template:
          volume_level: 0.45
        data_template:
# Add a delay in a length which you think fits best for all the things you want to say over TTS
      - delay:
          seconds: 1
      - delay: >-
          {% endif %}
        data_template:
          with_group: yes
Cant get this to work :frowning: It complaining about invalid config. It dosnt like the automation part i think?
17-02-19 23:49:24 ERROR (MainThread) [homeassistant.bootstrap] Invalid config for [automation]: [service] is an invalid option for [automation]. Check: automation->service. (See /home/hass/.homeassistant/configuration.yaml, line 163). Please check the docs at https://home-assistant.io/components/automation/
Failed config
Heres my config
coniguration.yaml
# Google Text to speech
tts:
  - platform: google
    cache: true
    cache_dir: /tmp/tts
    time_memory: 300
    language: 'sv'
# Include
group: !include groups.yaml
sensor: !include sensors.yaml
switch: !include switches.yaml
script: !include_dir_merge_named script
automation: !include_dir_merge_list automation
script/sonos_tts.yaml
# > SONOS TTS
  say:
    alias: SONOS TTS
    sequence:
        data_template:
          with_group: yes
        data_template:
        data_template:
          volume_level: 0.45
        data_template:
      - delay:
          seconds: 1
      - delay: >-
          {% endif %}
        data_template:
          with_group: yes
automation/sonos_test.yaml
    variables:
      where: 'kontor'
      what: 'Hej där!'
Could you post the hole content of your automation since the error you posted is about the automation, not about the script.
I couldn’t get it to work with the {{ where }} and {{ what }} either.
Now that I have placed the “where” and the “what” within the actual scripts, it works fine again…
Maby Im doing this wrong but the hole automation is:
    variables:
      where: 'kontor'
      what: 'Hej där!'
it is just for test before I include it in some automation that I have running. I have tried include it in this one but without luck.
- alias: "Mail vattenläcka diskbänk"
  initial_state: True
  hide_entity: False
    - platform: state
      entity_id: switch.fuktdiskbank
      to: 'on'
    - service: notify.gmailtoni
      data_template:
        title: "Vattenläcka under diskbänk"
        message: "Möjlig vattenläcka under diskbänk kontrollera"
    - service: notify.gmailmalin
      data_template:
        variables:
          where: 'kontor'
          what: 'Hej där!'
@Toni: This is not even not a half automation ;). If something should be automated there are two things essential: what shall be automated an when - you are totaly missing the when part. I would recommend walking through the hole automation tutorial setp by step, since this is the most essential thing within HA and home automation: Automating Home Assistant - Home Assistant
As you can see, I have not quite got the hang of this yet :slight_smile: I will have second look at the getting started :sweat: It was not mention to be a full automation just something simple i could manually trigger from the frontend.
What about the following automation? This automation works fine without the last sonos part. Here im trying to send a tts message to one sonos speaker “media_media_player.kontor” after 2 email has been sent.
 - alias: "mail water leak"
   initial_state: True
   hide_entity: False
     - platform: state
       to: 'on'
       data_template:
         title: "Water leaks under kitchen sink"
         message: "Possible water leak under kitchen sink."
       data_template:
         variables:
           where: 'kontor'
           what: 'Hello!'
@domlen Can you see whats wrong with the automation above?
Can you paste your script code aswell? Do you get an error message?
Heres my script.
# SONOS TTS
  say:
    alias: SONOS TTS
    sequence:
        data_template:
          with_group: yes
        data_template:
        data_template:
          volume_level: 0.45
        data_template:
      - delay:
          seconds: 1
      - delay: >-
          {% endif %}
        data_template:
          with_group: yes
The error I get:
Failed config
So I think the script is ok.
whats on line 163 in your configuration.yaml
