I love. Gonna do it now and put it in dashboard. Man I’ve been trying for hours to get exchange calender to sync with google. How are you doing that? Thanks!!
Nice man, thanks again!! I wanted this forever and never got it to work lol. thank you!
Anytime! I had another thread I started for finding travel time from a google calendar and creating an alert when it’s time to leave. I built on that quite a bit so I may add to that thread, I’ll send you the link in a PM. Probably won’t have time to post for a day or so but I will send it to you.
I’m not using Exchange for my google calendar. But I do use iCloud predominantly and I find that creating a iCal link and imported into Google does seem to work just fine. It syncs only every 12 hours or so but it does work.
So I’m using this script for my TTS and it works great if I want only one speaker to talk, now Im thinking I would like to create a group for certain things, not sure how to modify
TTS Script
- sonos_say:
alias: "Sonos TTS script"
sequence:
- service: media_player.sonos_snapshot
data_template:
entity_id: "{{ sonos_entity }}"
- service: media_player.sonos_unjoin
data_template:
- service: media_player.volume_set
data_template:
volume_level: "{{ volume }}"
- service: tts.google_say
data_template:
message: "{{ message }}"
- delay: "{{ delay }}"
- service: media_player.sonos_restore
data_template:
Does anyone know if there is a way to set a number of random messages for ‘What’ in the automation? It would be good to have a number of random messages.
How can I add a state variable at the message field, such that the message is something like
what: "Temperature is {{states('sensor.now_temperature')}}."
I can’t seem to pass the sensor variable…
Try “Temperature is {{ states.sensor.now_temperature.state }}.”
Thanks. That, plus switching to
`data_template`
instead of
`data`
on the automation side worked!
Does anyone have any audio sync issues with multiple Sonos speakers? It seems like they all don’t start at the same time so there is an echo.
You need to join them first and then set the message to play to the group, not specific speakers.
@CtrlX Thanks! I was joining the ones I wanted then also had them all defined in the tts.google_say
service definition. If I would have read the script a little closer I would have noticed that only the master is defined there.
Appreciate it!
I would also like to have that feature. Additionally, I am interested in how you organize your messages in your config to have them use states of sensor etc.
Hi Guys
I have read most of this thread and various others. Having spent two days unsuccessfully trying to get the SONOS TTS service to work I am hoping someone here can point me in the right direction.
Currently I have followed the script in Post #1, as follows
# > SONOS TTS
say:
alias: Sonos Text To Speech
sequence:
entity_id: media_player.den
- delay: '00:00:07'
volume_level: 0.50
# - service: media_player.select_source
# data_template:
# entity_id:
# - media_player.den
# source: Hei!
message: "Good Morning"
# Add a delay in a length which you think fits best for all the things you want to say over TTS
- delay: '00:00:30'
My automation simply calls the script as follows
- alias: Notification Audio - Good morning weekday
- platform: time
at: '07:10:00'
#- delay: '00:00:30'
- service: script.turn_on
entity_id: script.say
Unfortunately, I hear nothing at the designated time or if I trigger the automation manually.
Any ideas? One thought I had reading other threads was my Fritzbox router could be an issue due to loopback NAT, but not really investigated that in any detail
Any help most welcome
I think you need “data_template:” instead of “data:”
Also, in the automation, “entity_id” should be the player, the script should be the service you want to use.
I have mine configured following the doc and it works great.
Thanks for the tip.
Just tried the configuration using VOICERSS. Still nothing.
I do not know if it is relevant, but this is a random error that I am getting the home-assistant log.
2017-12-10 22:51:42 ERROR (MainThread) [aiohttp.access] Error in logging
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 554, in __get__
return inst._cache[self.name]
KeyError: 'remote'
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 521, in log
for key, value in fmt_info:
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 513, in <genexpr>
for key, method in self._methods)
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 473, in _format_a
ip = request.remote
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 556, in __get__
val = self.wrapped(inst)
File "/usr/lib/python3.6/site-packages/aiohttp/web_request.py", line 319, in remote
peername = transport.get_extra_info('peername')
File "/usr/lib/python3.6/asyncio/sslproto.py", line 306, in get_extra_info
return self._ssl_protocol._get_extra_info(name, default)
File "/usr/lib/python3.6/asyncio/sslproto.py", line 547, in _get_extra_info
return self._transport.get_extra_info(name, default)
AttributeError: 'NoneType' object has no attribute 'get_extra_info'
Also I am using HASS.IO and Lets Encrypt.
Did you try using it in an automation only just to see if it works?
Edited CP, from mine:
- alias: TTS Test
- platform: time
at: '07:10:00'
data_template:
with_group: true
data_template:
data_template:
volume_level: 0
data_template:
volume_level: 0.6
- service: tts.voicerss_say
data_template:
message: This is a test!
- delay:
seconds: 2
- delay: "{% set duration = states.media_player.den.attributes.media_duration\
\ %} {% if duration > 0 %}\n {% set duration = duration - 1 %}\n{% endif %}\
\ {% set seconds = duration % 60 %} {% set minutes = (duration / 60)|int % 60\
\ %} {% set hours = (duration / 3600)|int %} {{ \"%02i:%02i:%02i\"|format(hours,\
\ minutes, seconds)}}"
data_template:
with_group: true
I will give it a go. I’ll let you know how I get on.
No luck. Still silence!
NEW UPDATE
Whilst testing the automation only, I see that a filename comes up in SONOS on Home Assistant. Something along the lines of
3ef4457…75dfc1991-en-US_voicerss.mp3. If I try to play this from my the web browser on my phone, I get the message Unable to play 3ef4457…75dfc1991-en-US_voicerss.mp3 unable to connect to xxxxx.duckdns.org
Not sure that it is significant, but I’ll take it as progress.
Any thoughts?
Yes, it creates a file in the TTS directory.
It should display the text you you put in as the message.
Maybe something to do with your duckdns, I’m using Amazon Polly without duckdns, so not sure what else needs to be checked.
