Hi all,
After a good deal of messing around with firewall rules I have several Sonos speakers communicating from one VLAN to another container my Home Assistant instance. Home Assistant runs in a docker container with several ports exposed to the host as needed. Sister services (Node Red, Mosquitto, etc) communicate using internal docker networks, and users have access through a reverse proxy (Traefik).
The problem is that although I have these speakers added to Home Assistant and tweak controls etc, I can not get TTS working or local media working. No error messages or anything helpful that I can see. The current media stream simply pauses for a short period of time and then resumes. Radio Streams work fine. TTS (Piper and Google) performs as expected in other contexts. This is where I need some help.
Some details for my network configuration:
- All ports from Home Assistant VLAN to Speaker VLAN allowed
- Ports 1400 and 1443 from Speaker VLAN to Home Assistant VLAN allowed (see Sonos - Home Assistant)
- The docker container does not run in host network mode. I explicitly expose certain ports as needed, and I am hesitant to change this.
Here is my docker compose service:
homeassisstant:
container_name: homeassistant
image: ghcr.io/home-assistant/home-assistant:stable
restart: unless-stopped
volumes:
- "${CONF_DIR}/homeassistant:/config"
- "/etc/localtime:/etc/localtime:ro"
environment:
- PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
- LANG=C.UTF-8
- S6_BEHAVIOUR_IF_STAGE2_FAILS=2
- S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0
- S6_CMD_WAIT_FOR_SERVICES=1
- S6_SERVICES_READYTIME=50
- WHEELS_LINKS=https://wheels.home-assistant.io/musllinux/
- S6_SERVICES_GRACETIME=
- TZ=${TZ}
privileged: true
ports:
# sonos reply
# https://www.home-assistant.io/integrations/sonos/#network-requirements
- 1400:1400
# sonos announce tts
- 1443:1443
networks:
proxy-server:
ha-backend:
depends_on:
- zigbee2mqtt
- mqtt
- influxdb
- unifi-network-application
labels:
# expose to traefik
- "traefik.enable=true"
# more traefik labels below...
… and Home Assistant yaml for Sonos:
media_player:
hosts:
# add all sonos speakers here. Fix IP addresses in DHCP server
- !secret sonos_speaker_livingroom_left_ip_address
- !secret sonos_speaker_livingroom_right_ip_address
# need to specify HA host for TCP 1400 and 1443
advertise_addr: !secret homeassistant_server_host_ip_address
Any suggestions? I can see from tcpdump
that a lot of requests are being sent to ports 32000-60000 (seemingly at random).
