Thanks! I decided to give it one last search before giving up and got your integration working! Got the info I need from it!
Volume control doesn’t work for me but I don’t need that.
@dontdoititoldyou Glad it was useful. For volume, does it work if you move the volume with the slider - i.e. choose a specific volume vs. up or down? If you want to have a look at the debug… if you turn the avr on, then select Enable Debug Logging on the device in the UI, then turn volume up and down and set the volume using the slider (remember the order you do it), and then turn off debug logging, it’ll give you a log file - post that here, or if you’re on github, post it as an issue there and I’ll take a quick look - easier while it’s fresh in my mind.
Oh, and then also could you re-enable debug logging, and just change the volume up and down using the knob or ir remote - i.e. just physically change the volume on the avr and then disable debug and post that as well.
submitted on GitHub
Thanks - sent my response there.
