I am setting up my Sony Blu-Ray w/ Home assistant. I have configured my configuration.yaml file & HA is asking for a pin to pair… however, my blu-ray player never provides me with a pin to pair with… any ideas? Thanks!
I see this error in my logs:
config $ more home-assistant.log|grep bravia
2020-01-30 16:33:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded braviatv from homeassistant.components.braviatv
2020-01-30 16:33:25 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.braviatv
2020-01-30 16:33:25 ERROR (SyncWorker_7) [braviarc.braviarc] [W] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/accessControl (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7095ac50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2020-01-30 16:40:08 ERROR (SyncWorker_10) [braviarc.braviarc] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/system (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x70940850>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/components/braviatv/media_player.py", line 313, in turn_on
self._braviarc.turn_on()
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 257, in turn_on
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 229, in get_command_code
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 222, in _refresh_commands
2020-01-30 16:40:10 ERROR (SyncWorker_16) [braviarc.braviarc] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/system (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6cb2cf90>: Failed to establish a new connection: [Errno 111] Connection refused'))
config $
Did you make any further progress on this? I have a UBP-X1000ES. It similarly does not seem to pair up with a PIN.
Hi @dickschoeller
Unfortunately, I did not solve this… my take away was that this works with Sony TVs but not Blu-ray
Thanks. I’ve been working to get media_player.sony working. Not quite there, but making progress.
Hey, thanks @dickschoeller - this worked for me (https://github.com/alexmohr/media_player.sony)
Can you describe a bit more? I’ve installed media_player.sony and I have some controls but only play/stop, next/previous and volume control. Is it possible to fully control the device from home assistant with this addon?
I just nfound out on my BR player that there’s an “app” on the player called “activate enhanced features” that provide the PIN code
