Sony Bravia tv lovelace custom tv remote card
I am setting up a gui lovelace frontend custom tv remote card ““GitHub - marrobHD/tv-card: 📺 TV Remote Card”” for the Sony bravia tv integration ““Sony Bravia TV - Home Assistant””
Developer tools service call yamel code below works
service: remote.send_command
entity_id: remote.sony_bravia_tv
command: ‘TvPower’
But by my custom card gui button only shows error
CustomCard yamel code
type: custom:tv-card
entity: sun.sun
tv: true
back:
Action: call-service
Command: return
service_data: null
channeldown:
Command: channeldown
service_data: null
channelup:
Command: channelup
service_data: null
down:
Command: down
service_data: null
forward:
Command: forward
service_data: null
home:
Command: home
service_data: null
info:
Command: null
service_data: null
left:
Command: left
service_data: null
play:
Command: play
service_data: null
power:
device_id: ea45a21074749a14c0aff266fd3c7810
command: TvPower
reverse:
Command: rewind
service_data: null
right:
Command: right
service_data: null
select:
Command: confirm
service_data: null
source:
Command: input
service_data: null
What am I missing I’m using the pin authorization but the service works in the developer tools?
Your code is hard to read due to not being formatted, but the general form of the services config should be, e.g.,
power:
  service_data:
    command: TvPower
Case is important. “Action” should be “action”, for instance.
Bottom-line: follow the custom card documentation more closely
Fixed thanks for the help here my fixed card code
You might have another id used the channelup and down for volume
entity: sun.sun
tv: true
back:
  service_data:
    command: Return
backs:
  service_data:
    command: Back
channeldown:
  service_data:
    command: VolumeDown
channelup:
  service_data:
    command: VolumeUp
down:
  service_data:
    command: Down
forward:
  service_data:
    command: Forward
home:
  service_data:
    command: Home
guide:
  service_data:
    command: Media
info:
  service_data:
    command: Info
up:
  service_data:
    command: Up
left:
  service_data:
    command: Left
play:
  service_data:
    command: Play
power:
  service_data:
    command: TvPower
reverse:
  service_data:
    command: Rewind
right:
  service_data:
    command: Right
select:
  service: Remote.send_command
  service_data:
    command: Confirm
source:
  service_data:
    command: TvInput
Do you mind to show us the fixed card code again, this time correctly formatted so other readers can make more sense out of it?
Inside the Editor just highlight the complete code you just did paste and hit the </> -button within the toolbar above. You’ll see the outcome inside the preview window to the right.
@skynet-network thanks for writing this out - I was able to reuse in my code!
the lovelace card broke after core-2021.11 used the GitHub - iantrich/roku-card: 📺 Roku Remote Card card insteed with apps keys
> Blockquote
type: custom:roku-card
entity: media_player.sony_bravia_tv
tv: true
apps:
  - image: null
    icon: mdi:netflix
    app: Netflix
    tap_action:
      action: call-service
      service: media_player.select_source
      service_data:
        source: Netflix
        entity_id: media_player.sony_bravia_tv
  - image: null
    icon: mdi:vhs
    app: youtube Kids
    tap_action:
      service_data:
        source: YouTube Kids
  - image: null
    icon: mdi:filmstrip
    app: prime video
    tap_action:
      service_data:
        source: Prime Video
  - image: null
    icon: mdi:youtube
    app: youtube
    tap_action:
      service_data:
        source: YouTube
power:
  tap_action:
    service_data:
      command: TvPower
volume_up:
  tap_action:
    service_data:
      command: VolumeUp
volume_down:
  tap_action:
    service_data:
      command: VolumeDown
volume_mute:
  tap_action:
    service_data:
      command: VolumeMute
up:
  tap_action:
    service_data:
      command: Up
down:
  tap_action:
    service_data:
      command: Down
left:
  tap_action:
    service_data:
      command: Left
right:
  tap_action:
    service_data:
      command: Right
home:
  tap_action:
    service_data:
      command: Home
Info:
  tap_action:
    service_data:
      command: Input
back:
  tap_action:
    service_data:
      command: Return
select:
  tap_action:
    service_data:
      command: Confirm
reverse:
  tap_action:
    service_data:
      command: Rewind
play:
  tap_action:
    service_data:
      command: Play
Forward:
  tap_action:
    service_data:
      command: Forward
> Blockquote
For poeple seeking for examples:
entity: sun.sun
tv: true
select:
  service_data:
    command: Confirm
    entity_id: remote.sony_xr_77a83j
up:
  service_data:
    command: Up
down:
  service_data:
    command: Down
left:
  service_data:
    command: Left
right:
  service_data:
    command: Right
power:
  service: media_player.turn_on
  service_data:
    device_id: 84f5c31bd728dce0fb1527e779b91156
applications:
  Ampli:
    icon: mdi:amplifier
    service: trigger.automation
    service_data:
      entity_id: automation.ampli_bravia
  Bravia_Power_On:
    icon: mdi:power-plug-off
    service: switch.turn_off
    service_data:
      entity_id: switch.salon_1_bravia
  Bravia_Power_Off:
    service: switch.turn_on
    service_data:
  V+:
    icon: mdi:volume-plus
    service_data:
      device: Ampli
      command: VolumeUp
      entity_id: remote.stargate
  V-:
    icon: mdi:volume-minus
    service_data:
      device: Ampli
      command: VolumeDown
  Mute:
    icon: mdi:volume-mute
    service_data:
      device: Ampli
      command: VolumeDown
  Home:
    icon: mdi:home
    service_data:
      command: Home
  Netflix:
    icon: mdi:netflix
    service_data:
      command: Netflix
  HDMI1:
    icon: mdi:hdmi-port
    service_data:
      command: Hdmi1
Is there a way to create buttons for apps?
I have successfully added the Netlix but it was build in app, how can I add the Disney+ for example?
I think you can using URI but I don’t know the syntax for that. Have you checked what commands does your TV supports ?
For example, mine returns:
  "result": [
        "title": "Play Store",
        "uri": "com.sony.dtv.com.android.vending.com.google.android.finsky.tvmainactivity.TvMainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.android.vending.com.google.android.finsky.tvmainactivity.TvMainActivity.png"
        "title": "YouTube",
        "uri": "com.sony.dtv.com.google.android.youtube.tv.com.google.android.apps.youtube.tv.activity.ShellActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.google.android.youtube.tv.com.google.android.apps.youtube.tv.activity.ShellActivity.png"
        "title": "YouTube Music",
        "uri": "com.sony.dtv.com.google.android.youtube.tvmusic.com.google.android.apps.youtube.tvmusic.activity.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.google.android.youtube.tvmusic.com.google.android.apps.youtube.tvmusic.activity.MainActivity.png"
        "title": "Music",
        "uri": "com.sony.dtv.com.sony.dtv.osat.music.com.sonyericsson.music.MusicActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.osat.music.com.sonyericsson.music.MusicActivity.png"
        "title": "Media Player",
        "uri": "com.sony.dtv.com.sony.dtv.smartmediaapp.com.sony.dtv.smartmediaapp.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.smartmediaapp.com.sony.dtv.smartmediaapp.MainActivity.png"
        "title": "Timers &amp; Clock",
        "uri": "com.sony.dtv.com.sony.dtv.timers.com.sony.dtv.activity.TimersMainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.timers.com.sony.dtv.activity.TimersMainActivity.png"
        "title": "TV",
        "uri": "com.sony.dtv.com.sony.dtv.tvx.com.sony.dtv.tvx.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.tvx.com.sony.dtv.tvx.MainActivity.png"
        "title": "Launchy Launcher",
        "uri": "com.sony.dtv.com.hugegreenbug.launchy.com.hugegreenbug.launchy.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.hugegreenbug.launchy.com.hugegreenbug.launchy.MainActivity.png"
        "title": "TED",
        "uri": "com.sony.dtv.com.ted.android.tv.com.ted.android.tv.view.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.ted.android.tv.com.ted.android.tv.view.MainActivity.png"
        "title": "Prime Video",
        "uri": "com.sony.dtv.com.amazon.amazonvideo.livingroom.com.amazon.ignition.IgnitionActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.amazon.amazonvideo.livingroom.com.amazon.ignition.IgnitionActivity.png"
        "title": "Apple TV",
        "uri": "com.sony.dtv.com.apple.atve.sony.appletv.com.apple.atve.sony.appletv.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.apple.atve.sony.appletv.com.apple.atve.sony.appletv.MainActivity.png"
        "title": "Play Games",
        "uri": "com.sony.dtv.com.google.android.play.games.com.google.android.apps.play.games.app.atv.features.home.HomeActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.google.android.play.games.com.google.android.apps.play.games.app.atv.features.home.HomeActivity.png"
        "title": "Play Movies &amp; TV",
        "uri": "com.sony.dtv.com.google.android.videos.com.google.android.videos.tv.presenter.activity.TvLauncherActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.google.android.videos.com.google.android.videos.tv.presenter.activity.TvLauncherActivity.png"
        "title": "Netflix",
        "uri": "com.sony.dtv.com.netflix.ninja.com.netflix.ninja.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.netflix.ninja.com.netflix.ninja.MainActivity.png"
        "title": "Calman for BRAVIA",
        "uri": "com.sony.dtv.com.sony.dtv.calibrationmonitor.com.sony.dtv.calibrationmonitor.ActionCheckActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.calibrationmonitor.com.sony.dtv.calibrationmonitor.ActionCheckActivity.png"
        "title": "Eco Dashboard",
        "uri": "com.sony.dtv.com.sony.dtv.ecodashboard.com.sony.dtv.ecodashboard.presentation.activity.EcoDashboardActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.ecodashboard.com.sony.dtv.ecodashboard.presentation.activity.EcoDashboardActivity.png"
        "title": "Living Decor",
        "uri": "com.sony.dtv.com.sony.dtv.livingfit.com.sony.dtv.livingfit.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.livingfit.com.sony.dtv.livingfit.MainActivity.png"
        "title": "BRAVIA notifications",
        "uri": "com.sony.dtv.com.sony.dtv.notificationcenter.com.sony.dtv.notificationcenter.NotificationCenterActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.notificationcenter.com.sony.dtv.notificationcenter.NotificationCenterActivity.png"
        "title": "My BRAVIA",
        "uri": "com.sony.dtv.com.sony.dtv.promos.com.sony.dtv.promos.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.promos.com.sony.dtv.promos.MainActivity.png"
        "title": "Title List",
        "uri": "com.sony.dtv.com.sony.dtv.recapp.com.sony.dtv.recapp.MainActivityIcon",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.recapp.com.sony.dtv.recapp.MainActivityIcon.png"
        "title": "Help",
        "uri": "com.sony.dtv.com.sony.dtv.smarthelp.com.sony.dtv.smarthelp.activity.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.smarthelp.com.sony.dtv.smarthelp.activity.MainActivity.png"
        "title": "Sony Select",
        "uri": "com.sony.dtv.com.sony.dtv.sonyselect.com.sony.dtv.sonyselect.activities.LaunchActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.sonyselect.com.sony.dtv.sonyselect.activities.LaunchActivity.png"
        "uri": "com.sony.dtv.com.sony.dtv.timers.com.sony.dtv.timers.activity.TimersMainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sony.dtv.timers.com.sony.dtv.timers.activity.TimersMainActivity.png"
        "title": "BRAVIA CORE",
        "uri": "com.sony.dtv.com.sonypicturescore.com.sphe.bravialounge.SplashActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.sonypicturescore.com.sphe.bravialounge.SplashActivity.png"
        "title": "Internet Browser",
        "uri": "com.sony.dtv.com.vewd.core.integration.dia.com.vewd.core.integration.dia.SonyBrowserUiActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.vewd.core.integration.dia.com.vewd.core.integration.dia.SonyBrowserUiActivity.png"
        "title": "Play RTS",
        "uri": "com.sony.dtv.ch.rts.player.ch.srg.srgplayer.tv.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.ch.rts.player.ch.srg.srgplayer.tv.MainActivity.png"
        "title": "PlaySuisse",
        "uri": "com.sony.dtv.ch.srgssr.playsuisse.tv.ch.srgssr.playsuisse.tv.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.ch.srgssr.playsuisse.tv.ch.srgssr.playsuisse.tv.MainActivity.png"
        "title": "File Manager +",
        "uri": "com.sony.dtv.com.alphainventor.filemanager.com.alphainventor.filemanager.activity.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.alphainventor.filemanager.com.alphainventor.filemanager.activity.MainActivity.png"
        "title": "APKMirror Installer (beta)",
        "uri": "com.sony.dtv.com.apkmirror.helper.prod.com.apkmirror.presentation.start.StartActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.apkmirror.helper.prod.com.apkmirror.presentation.start.StartActivity.png"
        "title": "Paramount+",
        "uri": "com.sony.dtv.com.cbs.ca.com.paramount.android.pplus.splash.tv.ui.activity.SplashActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.cbs.ca.com.paramount.android.pplus.splash.tv.ui.activity.SplashActivity.png"
        "title": "CuriosityStream",
        "uri": "com.sony.dtv.com.curiosity.curiositystream.androidtv.com.curiosity.activities.OnboardingActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.curiosity.curiositystream.androidtv.com.curiosity.activities.OnboardingActivity.png"
        "title": "Disney+",
        "uri": "com.sony.dtv.com.disney.disneyplus.com.bamtechmedia.dominguez.main.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.disney.disneyplus.com.bamtechmedia.dominguez.main.MainActivity.png"
        "title": "Sunrise TV",
        "uri": "com.sony.dtv.com.lgi.upcch.com.libertyglobal.horizonx.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.lgi.upcch.com.libertyglobal.horizonx.MainActivity.png"
        "title": "NordVPN",
        "uri": "com.sony.dtv.com.nordvpn.android.com.nordvpn.android.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.nordvpn.android.com.nordvpn.android.MainActivity.png"
        "title": "Cast for PICO",
        "uri": "com.sony.dtv.com.pico.screencast.com.pico.screencast.SplashActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.pico.screencast.com.pico.screencast.SplashActivity.png"
        "title": "Vimeo",
        "uri": "com.sony.dtv.com.vimeo.android.videoapp.com.vimeo.android.videoapp.core.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.com.vimeo.android.videoapp.com.vimeo.android.videoapp.core.MainActivity.png"
        "title": "Fully Kiosk Browser",
        "uri": "com.sony.dtv.de.ozerov.fully.de.ozerov.fully.TvActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.de.ozerov.fully.de.ozerov.fully.TvActivity.png"
        "title": "6play",
        "uri": "com.sony.dtv.fr.m6.m6replay.fr.m6.m6replay.tv.activity.SplashActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.fr.m6.m6replay.fr.m6.m6replay.tv.activity.SplashActivity.png"
        "title": "ARTE",
        "uri": "com.sony.dtv.tv.arte.plus7.tv.arte.plus7.leanback.MainActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.tv.arte.plus7.tv.arte.plus7.leanback.MainActivity.png"
        "title": "Rakuten TV",
        "uri": "com.sony.dtv.tv.wuaki.apptv.tv.wuaki.apptv.activity.TVLaunchActivity",
        "icon": "http://192.168.1.159/DIAL/icon/com.sony.dtv.tv.wuaki.apptv.tv.wuaki.apptv.activity.TVLaunchActivity.png"
  "id": 1
To be honest I’m still learning HA. How can I check that?
For instance, this is not HA but Bravia :slight_smile:
curl -H 'Content-Type: application/json' -H 'X-Auth-PSK:<preshared key>' -X POST -d "{'id': 1, 'method': 'getApplicationList', 'version': '1.0', 'params': ['']}" http://<Bravia IP>/sony/appControl
Replace with your key. You can find it on your TV, under Settings > Network & Internet > Home Network > IP Control > Pre-Shared Key.
You have to set Authentication to “Normal and Pre-Shared Key”
Then you can copy/paste the result on a website like https://jsonbeautifier.org/ to make it readable
I wasn’t able to get the curl command above to work thought I tried it from HASS terminal, my unraid box, and from Windows.
However, I was able to get the commands by following the process here using a REST addon for my browser (I used Firefox).
[https://openremote.github.io/archive-dotorg/forums/Sony TV HTTP control.html#comment-23601972](https://openremote.github.io/archive-dotorg/forums/Sony TV HTTP control.html#comment-23601972)
Here’s the remote yaml I’m using:
entity: sun.sun
tv: true
select:
  service_data:
    command: Confirm
    entity_id: remote.sony_xbr_55x810c
up:
  service_data:
    command: Up
down:
  service_data:
    command: Down
left:
  service_data:
    command: Left
right:
  service_data:
    command: Right
power:
  service: media_player.toggle
  service_data:
    device_id: bfb8f1440a207a4af432f7e2f7ed3432
applications:
  V+:
    service_data:
      command: VolumeUp
  V-:
    service_data:
      command: VolumeDown
  Mute:
    service_data:
      command: Mute
  Netflix:
    icon: mdi:netflix
    service_data:
      command: Netflix
  hdmi4:
    icon: mdi:hdmi-port
    service_data:
      command: Hdmi4
  Home:
    icon: mdi:home
    service_data:
      command: Home
