Sony Projector ADCP control
I needed more control for my Sony projector (VPL-VW5000), so using Claude (Anthropic) I vibe coded this integration that gives more control than the native integration as well as visibility into various attributes (eg, status of power, input, brightness, contrast, sharpness and contrast).
Yes, 100% vibe coded.
Sony Projector ADCP Integration for Home Assistant
This custom integration allows you to control Sony projectors (specifically the VPL-XW5000 and compatible models) using the ADCP (Advanced Display Control Protocol) over your local network.
Features
Core Media Player Controls
  • Power On/Off: Standard media player power control
  • Input Selection: Switch between HDMI 1 and HDMI 2
  • Status Monitoring: Real-time status updates every 30 seconds
Additional Controls via Services
All advanced controls are accessible through custom media player services:
  • Picture Adjustments: Brightness, Contrast, Sharpness, Light Output (0-100)
  • Picture Modes: Cinema Film 1/2, Reference, TV, Photo, Game, Bright Cinema/TV, User 1/2/3
  • Menu Navigation: Menu, Up, Down, Left, Right, Enter, Reset
  • Video Mute: Blank screen function
Important Limitations
:warning: Volume Control Not Supported: The VPL-XW5000 does not support volume control commands via ADCP protocol. This is a hardware limitation of the projector model, not the integration.
Supported Models
This integration has been developed for the Sony VPL-XW5000 but should work with other Sony projectors that support the ADCP protocol, including:
  • VPL-XW5000, VPL-XW5100
  • VPL-XW6000, VPL-XW6100
  • VPL-XW7000
  • VPL-XW8100
  • VPL-VW series (check compatibility in the protocol manual)
Installation
HACS (Recommended)
  1. Open HACS in Home Assistant
  2. Click on “Integrations”
  3. Click the three dots in the top right corner
  4. Select “Custom repositories”
  5. Add this repository URL and select “Integration” as the category
  6. Click “Install”
  7. Restart Home Assistant
Manual Installation
  1. Copy the custom_components/sony_projector_adcp folder to your Home Assistant’s custom_components directory
  2. If the custom_components directory doesn’t exist, create it in the same location as your configuration.yaml file
  3. Restart Home Assistant
Configuration
  1. Go to Settings → Devices & Services
  2. Click + Add Integration
  3. Search for “Sony Projector ADCP”
  4. Enter your projector’s details:
    • IP Address: The IP address of your projector on your network
    • Port: Default is 53595 (usually doesn’t need to be changed)
    • Name: Friendly name for your projector
    • Use Authentication: Whether to use password authentication (default: enabled)
    • Password: Authentication password (default: “Projector”)
Network Setup on Projector
Ensure your projector is configured for network control:
  1. On your projector, go to the menu
  2. Navigate to Installation → Network Settings
  3. Set Network Management to ON or set Standby Mode to Standard
  4. Configure network settings (IP address, etc.)
  5. Note the Authentication Password if authentication is enabled
Usage
Media Player Entity
The integration creates a single media player entity: media_player.sony_projector
Standard Media Player Controls:
  • media_player.turn_on - Power on the projector
  • media_player.turn_off - Power off the projector
  • media_player.select_source - Switch input (HDMI 1 or HDMI 2)
Attributes:
  • source - Current input source
  • video_muted - Video mute status
  • picture_mode - Current picture mode
  • brightness - Current brightness level (0-100)
  • contrast - Current contrast level (0-100)
  • sharpness - Current sharpness level (0-100)
  • light_output - Current light output level (0-100)
Custom Services
All advanced controls are accessed through custom services:
Menu Navigation
service: sony_projector_adcp.send_key
  entity_id: media_player.sony_projector
  key: menu  # Options: menu, up, down, left, right, enter, reset, blank
Picture Mode
service: sony_projector_adcp.set_picture_mode
  mode: cinema_film1  # Options: cinema_film1, cinema_film2, reference, tv, photo, game, brt_cinema, brt_tv, user1, user2, user3
Picture Adjustments
service: sony_projector_adcp.set_brightness
  value: 75  # 0-100
service: sony_projector_adcp.set_contrast
  value: 80  # 0-100
service: sony_projector_adcp.set_sharpness
  value: 50  # 0-100
service: sony_projector_adcp.set_light_output
  value: 90  # 0-100
Examples
Automation - Movie Night Setup
automation:
  - alias: "Movie Time"
      - platform: time
        at: "20:00:00"
      - service: media_player.turn_on
      - delay:
          seconds: 30  # Wait for projector to warm up
      - service: sony_projector_adcp.set_picture_mode
          mode: cinema_film1
      - service: media_player.select_source
          source: "HDMI 1"
      - service: sony_projector_adcp.set_brightness
          value: 50
Script - Gaming Mode
script:
  projector_gaming_mode:
    alias: "Gaming Mode"
    sequence:
          mode: game
          source: "HDMI 2"
          value: 70
Lovelace Card
type: entities
entities:
  - entity: media_player.sony_projector
    type: custom:button-card
    tap_action:
      action: toggle
  - type: attribute
    attribute: picture_mode
  - type: attribute
    attribute: brightness
title: Sony Projector
Or use a media player card:
type: media-control
Troubleshooting
Cannot Connect
  • Verify the projector’s IP address is correct
  • Ensure the projector is on the same network as Home Assistant
  • Check that Network Management is enabled on the projector
  • Verify the port (default 53595) is correct
  • Check if a firewall is blocking the connection
Authentication Fails
  • Verify the password matches the projector’s authentication password
  • Check if authentication is enabled on both the projector and in the integration config
  • Default password is “Projector” (case-sensitive)
Commands Not Working
  • Ensure the projector is powered on (most commands only work when on)
  • Check Home Assistant logs for error messages
  • Try power cycling the projector
Values Not Updating
  • The integration polls the projector every 30 seconds
  • Some values may only be available when the projector is powered on
  • Check network connectivity
Debug Logging
To enable debug logging, add this to your configuration.yaml:
logger:
  default: info
  logs:
    custom_components.sony_projector_adcp: debug
Contributing
Contributions are welcome! Please feel free to submit a Pull Request.
License
This project is licensed under the MIT License.
Credits
Based on Sony’s ADCP protocol documentation for professional projectors.
Hi Ben,
Thanks for sharing this. i was about to build one for me and stumbled upon yours. Thanks for the great work, i am getting this error while importing this to HACS
i found the issue, and got it to work locally, it was missing the hacs structure, i updated it, can you please update the code with the following changes ? you can extract my structure to the root of your project and commit https://drive.google.com/file/d/1cKhBAhXJjiAeyQifAThr9eRc95BYmwkT/view?usp=share_link
I fixed the directory structure to be HACS compliant. It should work now.
This is exactly what I was looking for. Thanks!
Exactly what I need, thank you!
I was thinking on working on an integration to do this next having just finished one for my Loewe TV. I was surprised that my SonyPj wasn’t covered already.
Not 100% sure this will work for my Sony VPL-VW760ES, but I’m certainly going to give it a go!
It should be covered – please let me know if it works!
Got around to adding this today. Connected up to my VPL-VW760ES out of the box.
Can I ask if there is a way to recall image position settings? I couldn’t see it in the documentation?
Barry
@bcukier thank you for this integration. I set it up today on my vw385es after struggling for a week with the pjlink integration.
“Recall” position isn’t in the current integration. I’m not sure my projector has that. If you know which sdcp commands you are looking for, I can probably add them this weekend. Here is the reference I used (I think the ones you need may be on p13). Protocol manual
Would adding command to turn Reality Creation on/off be possible? I asked an LLM and recommended this feature on GitHub, but they tend to hallucinate on what is possible. Thank you!
I will look into it this weekend!
Any update on this? Thanks!
I updated the integration with two functionalities.
First, I added reality_creation:
# Turn on
service: sony_projector_adcp.set_reality_creation
  state: "on"
# Toggle
service: sony_projector_adcp.toggle_reality_creation
# Check state
{{ state_attr('media_player.sony_projector', 'reality_creation') }}
Second, I added the ability to pass through any other command to the projector:
# Set any parameter
service: sony_projector_adcp.send_raw_command
  command: 'color_temp "d65"'
# Query any value
  command: 'brightness ?'
Copy the updated files to your repository and you’re good to go! The raw command service gives you complete access to any ADCP command from the protocol manual. Be sure to format it correctly!
I don’t have the reality creation command on my projector, so please test it and provide me any feedback if it doesn’t work.
It works great on my end (Bravia 8 Projector), thank you! So nice to turn it on and off depending on the input button I press with my flexfob remote. I want it OFF for anything gaming (PC/PS5) but ON for anything movies/TV related (AppleTV, NVIDIA Shield), etc.
Great to hear.
I know there is a lot of derision elsewhere in this community about AI generated code, but it’s been a godsend for me (a finance guy) to get functionality for less supported devices like the Sony Projectors or Focal Amps.
Following the HACS Installation method, I don’t see option 4 ( Select “Custom repositories”), only “Application credentials”.
Also, can’t follow the “Manual” method using VirtualBox on a Mac Silicone, the VMDK I downloaded doesn’t seem to have “Guest Editions” installed, so I can’t use File Manager to copy the folder to the VM…
Any idea if I’ll even be able to control a VPL-FHZ80 for things like Lens Shift etc.?
Hi. I think (?) I wrote one of the first of these about 8 years ago. I thought I would take a stab at it again. I ended up looking at all current variations of this, and tried to make an “ultimate” version to incorporate all the good things of the various stuff.
Anyway, if you’re using a Sony projector with ADCP, you might want to take a look. It’s in HACS. I have been trying it today on my own projector, and seems to be working well, but would love to have some Sony projector people take a run and test.
It does things like auto-discovery, deals with IP addresses changing through serial number, uses UDP packets the projector emits instead of polling, and generally tries to do things “best practice” Home Assistant wise.
Awesome. Thank you for taking this to the next level. I will try it out this weekend and report back.
