I’m trying to setup a Sony VPL-PWZ10 Projector with PJLink. Here’s what I have in /config/configuration.yaml
media_player:
- platform: pjlink
host: 10.0.12.20
password: thisisnotmypassword
I’m getting this error.
Error while setting up platform pjlink
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/pjlink/media_player.py", line 50, in setup_platform
device = PjLinkDevice(host, port, name, encoding, password)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/pjlink/media_player.py", line 75, in __init__
self._name = projector.get_name()
File "/usr/local/lib/python3.7/site-packages/pypjlink/projector.py", line 227, in get_name
param = self.get('NAME')
File "/usr/local/lib/python3.7/site-packages/pypjlink/projector.py", line 130, in get
success, response = protocol.send_command(self.f, body, '?', self.encoding)
File "/usr/local/lib/python3.7/site-packages/pypjlink/protocol.py", line 71, in send_command
resp_body, resp_param = parse_response(f, encoding)
File "/usr/local/lib/python3.7/site-packages/pypjlink/protocol.py", line 29, in parse_response
header = data[0]
IndexError: string index out of range
I think the main part is the “string index out of range”. I have PJLink enabled in the Sony Projector through the web and I have the password set. I tried without a password and disabled the password in the Sony web interface, but Home Assistant gave an error that a password was required.
I ran a port scan and that shows port 4352 open, which is the default port for PJLink.
