Hi, I’ve had set up my Sony Bravia TV and was able to operate this with HASSIO (read status, set channel, on/off, etc.) However now it seems that the TV can no longer be operated and the ‘history’ shows the TV toggling on/off. The issue seems the same as the one below:
https://github.com/home-assistant/home-assistant/issues/16446
Anyone facing this issue? As I’ve just switched from local access to remote access via DuckDNS I’m think that there might be a relation.
This I found in the logging:
2019-01-23 22:35:19 ERROR (SyncWorker_13) [braviarc.braviarc] Exception: HTTPConnectionPool(host=‘192.168.178.171’, port=80): Max retries exceeded with url: /sony/audio (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x6f53c8f0>, ‘Connection to 192.168.178.171 timed out. (connect timeout=10)’))
2019-01-23 22:35:19 ERROR (SyncWorker_13) [homeassistant.components.media_player.braviatv] ‘NoneType’ object has no attribute ‘get’
The other network media device (e.g. receiver, media PC, Ziggo box) are still working properly in HASS
