I am using the RecycleApp to check out when what collection happens. It works great but in the frontend, the order is fixed by type. It would be very handy if I could sort by date. Anyone knows how to do this
The auto entities card is able to sort entities, and do much more fun stuff:
Yep. That’s doing the job. Thx
Note: it is a pitty you can not add a title to the card.
I do not know what card you put inside (entities?) but that is where the title should be set. The auto-entities card just provides the entitity ids.
Euh … ??? I lost you. I just added a new card, selected from the list of cards → Custom cards → Custom: Auto Entities. Addded the entities and set the filter.
I think what was meant was. . .
- You can copy or cut the current card you just made (saved to the clipboard)
- Create another card (like a Grid card or Vertical Stack card, which offers a title)
- Paste your card (from clipboard) into the Grid or Vertical Stack card
Why you can not add a title to the card?
type: custom:auto-entities
card:
type: entities
title: Afval <-----------------
card_mod:
style: |
ha-card {
background-color: rgba(0, 0, 0, 0);
filter:
include:
- name: Restafval
options:
image: /local/tmp/restafval.png
- name: Groenafval
options:
image: /local/tmp/groenafval.png
- name: Plastic
options:
image: /local/tmp/plasticafval.png
- name: Papier
options:
image: /local/tmp/papierafval.png
sort:
attribute: year_month_day_date
method: attribute
Ha! Imissed that one. Thx a lot!
Another tip:
Change the sort method to
sort:
method: attribute
Otherwise, if I remember correctly, when one of the garbage dates in your list is for example 02-06-2024 it will be on the top of your list.
