is there a way to sort the entities in the apex chart donut card after their own value?
So the highest value comes first, the second highest value the second and so on
in home assistant I have not yet found a way
Please post a SHORT MINIMAL code for a doughnut card which you wish improve.
Here’s one of my donuts, what I seek is to have the slices in descending order whereas they occur in the entity’s list order by default
type: custom:apexcharts-card
chart_type: donut
apex_config:
chart:
height: 500px
plotOptions:
pie:
donut:
labels:
show: true
total:
show: true
label: Total
formatter: |
EVAL:function(w) {
return (w.globals.seriesTotals.reduce((a, b) => a + b, 0) / 1000 * 1.05)
.toFixed(2)
.replace(/\B(?=(\d{3})+(?!\d))/g, ",") + " kW";
update_interval: 5sec
header:
show: true
show_states: true
colorize_states: true
standard_format: false
title: Live power usage
series:
- entity: sensor.sonoff_1000fd05e5_power
color: rgb(255,0,0)
- entity: sensor.sonoff_100169353e_power
- entity: sensor.sonoff_1000fd021f_power
- entity: sensor.sonoff_1001694739_power
- entity: sensor.sonoff_1000e7db7f_power
- entity: sensor.sonoff_1001121739_power
- entity: input_number.hws_power_watts_follower
- entity: sensor.sonoff_1001121a48_power
- entity: sensor.sonoff_1001121f94_power
- entity: sensor.sonoff_1001122101_power
- entity: sensor.sonoff_1000fcffe6_power
- entity: sensor.sonoff_10012c5536_power
- entity: sensor.sonoff_10009746cd_power
- entity: sensor.hot_tub_power_watts
- entity: sensor.sonoff_1001106294_power
color: rgb(30,255,0)
- entity: sensor.sonoff_10011218d2_power
name: Alf DW/HWS/Fridge
- entity: sensor.true_alfresco_ac_instant_w_rounded
- entity: sensor.upstairs_cooktop_oven_power
SHORT MINIMAL code?
not here to advocate ChatGPT (not allowed), but this seems an easy task for that language model. I did get an answer and explanation, please try for yourself and see what happens?
Seems that “short minimal code” is something absolutely unclear and it is normal to lay out tons of own code as is.
The minimal is:
type: custom:auto-entities
card:
chart_type: donut
card_param: series
filter: ...
sort:
method: state
If you need more per-entry customizations like “name” etc - you will have to learn how to use a “template” option of auto-entities.
It does go down a rabbit hole unfortunately, I went there first before I replied to this thread.
I was hoping there was something available such as
sorting: yes
method: descending
or similar
When I saw someone else asked, it peaked my interest to further the enquiry
I use the Auto Entities to display and sort the Entities in the Donut chart.
filter:
include:
- entity_id: sensor.*daily_energy_cost
exclude:
- state 1: "= 0"
- entity_id: sensor.gasverbrauch*energy_cost
- entity_id: sensor.esp_lesekopf_stromzahler_aktuelle_wirkleistung_*_energy_cost
show_empty: false
unique: true
sort:
method: state
reverse: true
card:
chart_type: donut
header:
title: Stromkosten pro Tag
show: true
show_states: false
apex_config:
legend:
show: false
dataLabels:
formatter: |
EVAL:function(value) {
return value.toFixed(0) + " %";
plotOptions:
pie:
donut:
labels:
show: true
total:
show: true
label: Total
formatter: |
EVAL:function(w) {
return w.globals.seriesTotals.reduce((a, b) => {return (a + b)} , 0).toFixed(2) + " €"
Scroll up a bit for an already provided simplified solution.
