gxc7719
(Gxc7719)
November 14, 2023, 3:30pm
1
It appears sound is broken again by a supervisor update. I’m running all the latest versions of ha. My sound was working fine until all of a sudden it wasn’t. After a lot of troubleshooting and research I found this:
opened 09:23AM - 10 Nov 23 UTC
bug
### Describe the issue you are experiencing
Earlier this week my system updated… to HA Supervisor 2023.11.0
Immediate the sound output of the board's 3.5mm output (via VLC addon as always) stopped working.
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### Steps to reproduce the issue
1. Update to Supervisor 2023.11.0
2. Play some sound on local audio output via VLC addon
### Anything in the Supervisor logs that might be useful for us?
```txt
Logger: homeassistant.components.vlc_telnet
Source: components/vlc_telnet/media_player.py:62
Integration: VLC media player via Telnet (documentation, issues)
First occurred: 8 november 2023 om 20:31:21 (2 occurrences)
Last logged: 10:15:38
Connection error: Failed to read: 0 bytes read on a total of undefined expected bytes. Partial bytes read: b''
### System Health information
## System Information
version | core-2023.11.1
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.6
os_name | Linux
os_version | 5.15.90
arch | aarch64
timezone | Europe/Amsterdam
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 5000
Installed Version | 1.33.0
Stage | running
Available Repositories | 1328
Downloaded Repositories | 7
</details>
<details><summary>AccuWeather</summary>
can_reach_server | ok
remaining_requests | 19
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 9.5
update_channel | stable
supervisor_version | supervisor-2023.11.0
agent_version | 1.4.1
docker_version | 20.10.22
disk_total | 113.9 GB
disk_used | 91.6 GB
healthy | true
supported | true
board | odroid-n2
supervisor_api | ok
version_api | ok
installed_addons | Samba share (10.0.2), Duck DNS (1.15.0), Home Assistant Google Drive Backup (0.111.1), NGINX Home Assistant SSL proxy (3.5.0), Node-RED (15.1.0), Plex Media Server (3.3.2), Advanced SSH & Web Terminal (15.1.0), WireGuard (0.9.0), AdGuard Home (4.8.17), VLC (0.2.0), Zigbee2MQTT (1.33.2-1), Mosquitto broker (6.3.1), chrony (2.6.2), ESPHome (2023.10.6), File editor (5.6.0), HomePod Connect (28.8-ls118), Whisper (1.0.0), Piper (1.4.0), Music Assistant BETA (2.0.0b74), openWakeWord (1.8.2)
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 2
views | 10
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 8 november 2023 om 18:04
current_recorder_run | 8 november 2023 om 19:05
estimated_db_size | 104.43 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
### Supervisor diagnostics
[config_entry-hassio-f9c2513652a4f6291037d6fa4f7c58d8.json.txt](https://github.com/home-assistant/supervisor/files/13317687/config_entry-hassio-f9c2513652a4f6291037d6fa4f7c58d8.json.txt)
### Additional information
_No response_
Hopefully this will be fixed soon.
