Not sure if this is the correct place to ask. Was running raspbian jessy and have set up a perfect combination. Had a speaker connected through a 3,5 jack (bathroom to play radio) and another one through bluetooth.
For this to work i used this config
- platform: vlc
arguments: ‘–alsa-audio-device=hw:0,0’ #JACK 3,5mm - platform: tts_bluetooth_speaker #bluetooth speaker with custom component
address: 00:13:EF:D2:00:96
volume: 0.7
Now after the reinstall i get the bluetooth working (this great tutorial and custom component https://github.com/pkozul/ha-tts-bluetooth-speaker ) . But all the sounds are coming through the bluetooth so i’m not able to play radio stream to bathroom. Just can’t figure out where is my 3,5 jack output. (Already ran raspi config and set it as default). Seems pulse audio has disabled it.
aplay -L
default
Playback/recording through the PulseAudio sound server
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
Running
vlc --alsa-audio-device=hw:0,X /home/homeassistant/.homeassistant/audio/files/alarm_clock.wav
Where 0.X (x is o…9) always plays through bluetooth as well
