INFO Reading configuration /config/esphome/Rack.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Detected timezone 'Europe/Brussels'
INFO Generating C++ source...
INFO Compiling app...
Processing rack (board: esp8285; framework: arduino; platform: platformio/espressif8266 @ 2.6.3)
Platform Manager: Installing platformio/espressif8266 @ 2.6.3
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: espressif8266 @ 2.6.3 has been installed!
The platform 'platformio/espressif8266 @ 2.6.3' has been successfully installed!
The rest of the packages will be installed later depending on your build environment.
Tool Manager: Installing platformio/toolchain-xtensa @ ~2.40802.0
Tool Manager: toolchain-xtensa @ 2.40802.200502 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif8266 @ ~2.20501.0
Tool Manager: framework-arduinoespressif8266 @ 2.20501.190515 has been installed!
Tool Manager: Installing platformio/tool-esptool @ <2
Tool Manager: tool-esptool @ 1.413.0 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.30000.0
Tool Manager: tool-esptoolpy @ 1.30000.201119 has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40200.0
Tool Manager: tool-scons @ 4.40200.0 has been installed!
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
| |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 2.0.0
| |-- <Hash> 1.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <ESP8266mDNS> 1.2
|-- <noise-c> 0.1.4
| |-- <libsodium> 1.10018.1
Compiling /data/rack/.pioenvs/rack/src/esphome/components/adc/adc_sensor.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/api_connection.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/api_server.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/list_entities.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/proto.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/user_services.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/api/util.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/binary_sensor/automation.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/binary_sensor/binary_sensor.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/binary_sensor/filter.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/esp8266/core.cpp.o
Compiling /data/rack/.pioenvs/rack/src/esphome/components/esp8266/gpio.cpp.o
src/esphome/components/esp8266/core.cpp:11:20: error: expected initializer before 'yield'
void IRAM_ATTR HOT yield() { ::yield(); }
src/esphome/components/esp8266/core.cpp:12:24: error: expected initializer before 'millis'
uint32_t IRAM_ATTR HOT millis() { return ::millis(); }
src/esphome/components/esp8266/core.cpp:13:20: error: expected initializer before 'delay'
void IRAM_ATTR HOT delay(uint32_t ms) { ::delay(ms); }
src/esphome/components/esp8266/core.cpp:14:24: error: expected initializer before 'micros'
uint32_t IRAM_ATTR HOT micros() { return ::micros(); }
src/esphome/components/esp8266/core.cpp:15:20: error: expected initializer before 'delayMicroseconds'
void IRAM_ATTR HOT delayMicroseconds(uint32_t us) { ::delayMicroseconds(us); }
src/esphome/components/esp8266/core.cpp:23:20: error: expected initializer before 'arch_feed_wdt'
void IRAM_ATTR HOT arch_feed_wdt() {
*** [/data/rack/.pioenvs/rack/src/esphome/components/esp8266/core.cpp.o] Error 1
src/esphome/components/esp8266/gpio.cpp: In member function 'virtual void esphome::esp8266::ESP8266GPIOPin::attach_interrupt(void (*)(void*), void*, esphome::gpio::InterruptType) const':
src/esphome/components/esp8266/gpio.cpp:43:51: error: 'attachInterruptArg' was not declared in this scope
attachInterruptArg(pin_, func, arg, arduino_mode);
src/esphome/components/esp8266/gpio.cpp: At global scope:
src/esphome/components/esp8266/gpio.cpp:88:16: error: expected initializer before 'ISRInternalGPIOPin'
bool IRAM_ATTR ISRInternalGPIOPin::digital_read() {
src/esphome/components/esp8266/gpio.cpp:92:16: error: expected initializer before 'ISRInternalGPIOPin'
void IRAM_ATTR ISRInternalGPIOPin::digital_write(bool value) {
src/esphome/components/esp8266/gpio.cpp:96:16: error: expected initializer before 'ISRInternalGPIOPin'
void IRAM_ATTR ISRInternalGPIOPin::clear_interrupt() {
*** [/data/rack/.pioenvs/rack/src/esphome/components/esp8266/gpio.cpp.o] Error 1
========================= [FAILED] Took 89.82 seconds =========================
Try doing a make clean and trying again.
Tried, even tried installing the beta, but no luck.
Changed configuration now it compiles
arduino_version: 2.7.2
#arduino_version: 2.5.1
For those who want a working configuration for SP111
substitutions:
devicename: "rack"
upper_devicename: "Gosund SP111"
# Higher value gives lower watt readout
current_res: "0.00237"
# Lower value gives lower voltage readout
voltage_div: "720"
wifi_ssid: !secret iot_wifi_ssid
wifi_pass: !secret iot_wifi_password
fallback_pass: !secret fallback_wifi_password
api_pass: !secret esp_api_password
ota_pass: !secret esp_ota_password
webserver_username: !secret webserver_username
webserver_password: !secret webserver_password
esphome:
platform: ESP8266
board: esp8285
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
password: "${api_pass}"
# Enable over the air updates
ota:
password: "${ota_pass}"
wifi:
ssid: "${wifi_ssid}"
password: "${wifi_pass}"
ap:
ssid: "${devicename} Fallback Hotspot"
password: "${fallback_pass}"
# see: https://esphome.io/components/time.html
time:
- platform: homeassistant
# Enable Web server
web_server:
port: 80
auth:
username: ${webserver_username}
password: ${webserver_password}
text_sensor:
- platform: version
name: "${devicename} - Version"
icon: mdi:cube-outline
binary_sensor:
- platform: status
name: "${devicename} - Status"
device_class: connectivity
# toggle relay on/off
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: button_switch
- platform: wifi_signal
name: "${devicename} - Wifi Signal"
update_interval: 60s
icon: mdi:wifi
- platform: uptime
name: "${devicename} - Uptime"
icon: mdi:clock-outline
- platform: total_daily_energy
name: "${devicename} - Todays Usage"
power_id: "power_wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
icon: mdi:calendar-clock
- platform: adc
pin: VCC
name: "${devicename} - VCC Volt"
icon: mdi:flash-outline
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO05
cf1_pin: GPIO04
change_mode_every: 4
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
update_interval: 3s
current:
name: "${devicename} - Ampere"
unit_of_measurement: A
accuracy_decimals: 3
icon: mdi:current-ac
voltage:
name: "${devicename} - Volt"
unit_of_measurement: V
accuracy_decimals: 1
power:
name: "${devicename} - Watt"
unit_of_measurement: W
icon: mdi:gauge
status_led:
pin:
number: GPIO00
inverted: True
output:
- platform: gpio
pin: GPIO02
inverted: True
switch:
name: "${devicename} - Switch"
icon: mdi:power
optimistic: true
turn_on_action:
- switch.turn_on: relay
turn_off_action:
- switch.turn_off: relay
- platform: gpio
pin: GPIO15
on_turn_on:
- output.turn_on: led_blue
on_turn_off:
- output.turn_off: led_blue
edit: chosen 2.7.2 because that worked with my other chips, … there’s no other particular reason. Just checked not defining a version also works. So maybe it’s better just to remove arduino_version all together.
Unless you have a reason to pin arduino_version just leave it out.
Thank you! I believe I had this from some sample core or another, a few of my devices had it pinned (to an ancient 2.4.4) and I got this error after updating ESPHome. Removed the pin and now I’m happily compiling again
