Spa heater nordpool price -> heat/no heat automation, any advice? SOLVED!
Hi there,
Any advice why the temperature wont change?
Price is well below 0 cents:
This is heater:
Here is the automation code I made in HA (visual / GUI, I’m bright as a deep hole in the space when it down to editing code manually )
alias: Poreallas alle 5snt → 40 astetta
description: “”
  • platform: numeric_state
    entity_id:
    • sensor.nordpool_kwh_fi_eur_4_40_024
      attribute: current_price
      above: -100
      below: 5
      for:
      hours: 24
      minutes: 0
      seconds: 0
      condition:
  • service: water_heater.set_temperature
    temperature: 40
    operation_mode: Boost
    mode: single
Please see section 11 about how to format your pasted code correctly: How to help us help you - or How to ask a good question
description: “”
entity_id:
  - sensor.nordpool_kwh_fi_eur_4_40_024
above: -100
below: 5
for:
  hours: 24
  minutes: 0
  seconds: 0
condition:
  temperature: 40
mode: single
Maybe Im just so stupid that I dont even understand the section 11, tried the demo but did not do anything…? :sweat:
Three back ticks around your code like this
Your code here
alias: Poreallas alle 5snt -> 40 astetta
description: ""
  - platform: numeric_state
    entity_id:
    above: -100
    below: 5
    for:
      hours: 24
      minutes: 0
      seconds: 0
condition: []
  - service: water_heater.set_temperature
      temperature: 40
mode: single
Device entity was wrong, should be climate. Also I changed the entity setting and added °C →
description: ""
    entity_id:
    above: -100
    below: 5
    for:
      hours: 24
      minutes: 0
      seconds: 0
condition: []
  - service: climate.set_temperature
      temperature: 40
      device_id: 6460133100f28fb85cb66a273c3ed93a
mode: single
Any idea how to make the temperature reset to 38°C at a certain time of day. Usually we use the spa between 17.00-20.00 and in winter it should stop heating at 15.00. IF the price has been right for the day :smiley:
