Hey folks,
I have successfully setup my SPC Vanderbilt Panel after installing the SPC Web Gateway. My ui-lovelave.yaml looks as follow:
- type: alarm-panel
entity: alarm_control_panel.dowstairs
show_keypad: true
states:
- arm_away
- disarm
- type: alarm-panel
entity: alarm_control_panel.upstairs
states:
- arm_away
- disarm
Considerations/Assumptions:
- I can see both entities have the
code_arm_required: true
attribute. - I can see examples of keypad needed to arm/disarm alarms in the house.
Questions:
How do I ensure entering the pin is prompted or a keypad is required whenever i need to arm/disarm the alarm?
I have tried to add a key_pad but it does not seem to work. I have followed:https://www.home-assistant.io/lovelace/alarm-panel/ but no luck so far and my card looks as follow (posting one as new users have 1 picture upload limit):
I know my binary_sensors are just sensors and i could not find many more entities from SPC but I wonder, what if one sensor is open (eg front door is open) and alarm can’t be armed? Is there any way I could force arming or inhibiting the open area?
How do I create just one card and select the area I want to arm/disarm from a drop down list (I know this could possibly apply to other useful things hence asking)?
Thanks in advance for your help.
L.
