Speaker with volume LED effects for volume control
I have been trying to make a small speaker with i2s and wanted to add some LED effects.
There are effects you can trigger on play, pause, idle, etc. But I wanted to display effect to “visualize” volume, when it changes.
I was not able to find anything, so I made my own with some help from folks on Discord:
esphome:
  friendly_name: Audio output 1
  on_boot:
    then:
      - light.turn_on:
          red: 20%
          green: 0%
          blue: 0%
          effect: "Slow pulse"
      - media_player.volume_set:
          volume: 10%
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  on_client_connected:
    - light.turn_off:
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  domain: !secret domain
  ap:
    ssid: "Esp32Audio1 Fallback Hotspot"
    password: "y74r3wv9L3sM"
captive_portal:
web_server:
  port: 80
  include_internal: True
  log: True
  local: True
  version: 3
status_led:
  pin:
    number: GPIO15
    inverted: False
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: GPIO4
    mode: stereo
    i2s_audio_id: i2sAudio1
    on_state:
      - lambda:
          if (id(volInternal).state != id(player1).volume) {
            ESP_LOGD("volume","We have volume change from %f to %f", volInternal->state, player1->volume);
            id(ledRing).turn_on().set_effect("volume bar").perform();
          } else {
            ESP_LOGW("volume", "Volume was not changed!");
            int outState = id(player1).state;
            if(outState == 2) id(ledRing).turn_on().set_effect("Walk").perform();
            if(outState == 4) id(ledRing).turn_on().set_effect("TTS").perform();
            if((outState != 0) && (outState != 2) && (outState != 4)) id(ledRing).turn_off().perform();
      - delay: 2s
      - lambda:
            ESP_LOGD("volume","We have END of volume change from %f to %f", volInternal->state, player1->volume);
            id(volInternal).state = id(player1).volume;
            if((outState != 2) && (outState != 4)) id(ledRing).turn_off().perform();
i2s_audio:
  i2s_lrclk_pin: GPIO27
  i2s_bclk_pin: GPIO25
light:
  - platform: neopixelbus
    type: GRB
    variant: ws2812
    num_leds: 9
    pin: GPIO16
    default_transition_length: 0s
    method:
      type: esp32_rmt
      channel: 0
    effects:
      - pulse:
          transition_length: 750ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
      - addressable_color_wipe:
          colors:
            - red: 22%
              green: 100%
              blue: 100%
              num_leds: 1
              gradient: true
            - red: 0%
              green: 0%
              blue: 0%
              num_leds: 3
          add_led_interval: 100ms
          reverse: false
          colors:
            - red: 50%
              green: 30%
              blue: 0%
              num_leds: 3
              gradient: true
            - red: 0%
              green: 0%
              blue: 0%
              num_leds: 6
          add_led_interval: 50ms
          reverse: true
      - addressable_lambda:
          lambda: |-
            int volLeds = 8 * (id(player1).volume + 0.08);
            // ESP_LOGD("volumeLEDS", "Current volume leds: %d", volLeds);
            it.all() = Color(200, 0, 0);
            it.range(0, 8 - volLeds) = Color(100, 100, 100);
button:
  - platform: restart
number:
    internal: True
    min_value: 0
    max_value: 1
    step: 0.01
    initial_value: 0.5
    optimistic: True
What it does is:
  • when volume changes, for 2 seconds it switches the effect to volume bar. This will shine LEDs in red according current volume and the rest will shine white. After 2 seconds, the effect will reset to what it was before - even during playback
  • when status is play, it will show effect Walk
  • when status is announce (Text to speech is used from HA), the effect will switch to TTS
Sounds great, is there a video?
What about when stopped, skipping track, paused?
Paused is status 2, that means the effect will go away. Skipped track still means you are in play mode, meaning the play animation will continue.
And video hot yet, but I can make one :slight_smile:
Cool. I have a couple of circular LEDs. Was thinking of making a little box with a rotary encoder, the LED and maybe a couple of buttons. Could be made to look like our other furniture, so would have significant other approval.
