Specified key was too long; max key length is 1000 bytes
since the last update (or maybe from the previous one) my instance cannot connect or create the db. So the recorder and the history cannot work properly.
The main error is the subject of this post, and this is the complete stacktrace:
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1802, in _execute_context
    self.dialect.do_execute(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 719, in do_execute
    cursor.execute(statement, parameters)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 206, in execute
    res = self._query(query)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/cursors.py", line 319, in _query
    db.query(q)
  File "/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py", line 259, in query
    _mysql.connection.query(self, query)
MySQLdb._exceptions.OperationalError: (1071, 'Specified key was too long; max key length is 1000 bytes')
  File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 730, in _setup_recorder
    self._setup_connection()
  File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 1098, in _setup_connection
    Base.metadata.create_all(self.engine)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/schema.py", line 4785, in create_all
    bind._run_ddl_visitor(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 3110, in _run_ddl_visitor
    conn._run_ddl_visitor(visitorcallable, element, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2113, in _run_ddl_visitor
    visitorcallable(self.dialect, self, **kwargs).traverse_single(element)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/visitors.py", line 524, in traverse_single
    return meth(obj, **kw)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 846, in visit_metadata
    self.traverse_single(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 902, in visit_table
    self.traverse_single(index, create_ok=True)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 933, in visit_index
    self.connection.execute(CreateIndex(index))
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1289, in execute
    return meth(self, multiparams, params, _EMPTY_EXECUTION_OPTS)
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/ddl.py", line 77, in _execute_on_connection
    return connection._execute_ddl(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1381, in _execute_ddl
    ret = self._execute_context(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1845, in _execute_context
    self._handle_dbapi_exception(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 2026, in _handle_dbapi_exception
    util.raise_(
  File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 207, in raise_
    raise exception
    db.query(q)
sqlalchemy.exc.OperationalError: (MySQLdb._exceptions.OperationalError) (1071, 'Specified key was too long; max key length is 1000 bytes')
[SQL: CREATE INDEX ix_states_entity_id_last_updated ON states (entity_id, last_updated)]
(Background on this error at: https://sqlalche.me/e/14/e3q8)
Can someone help me to solve this? I need to open a issues on github? I try to complete delete and let home assistant recreate it, but it did not work
