Specify 2 UPS's with NUT add-on
My HA is running on a thin client and I have one UPS connected to it. Within HA I was able to add it fairly easy. I just got a Raspberry Pi which is connected to another UPS. Is there a way to connect it as well using the NUT add-on? I assume the NUT add-on can be used to specify multiple UPS’s? I tried using the NUT integration using the IP address, but it fails and goes back to wanting to use localhost. Suggestions appreciated.
