Specify helpers in multiple yaml files
I would like to tidy up my helpers and keep them in multiple files in a “helpers” directory. I can’t seem to get this to work. So far I have:
configuration.yaml:
input_boolean: !include_dir_merge_list helpers/
helpers/TRVs.yaml:
input_boolean:
  - new_bool:
      icon: mdi:car
Any idea what I need to do to make this work? I don’t quite understand the syntax
input_boolean:  <----- remove this line
  - new_bool:
      icon: mdi:car
No that doesn’t work
It’s because there’s another error. Remove the hyphen. Multiple input booleans are defined as a dictionary not a list.
    new_bool:
      icon: mdi:car
    more_bool:
It also means you will need to change the include directive.
input_boolean: !include_dir_merge_named helpers/
Reference
Splitting up the configuration - Advanced usage
Awesome that got it thanks!
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a checkmark next to the topic’s title indicating that this topic has been solved. This helps other users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
I like placing different type of entities for a single topic into a single package: Packages - Home Assistant
For example I need input_button, input_number, cover entities for my blinds, so they are all in one file. And then other packages can also have these kind of entities, same with going through configuration.yaml
