Fulvi_Igor
(Fulvi Igor)
January 26, 2018, 10:43am
1
I’ve well setuped speech recognition via web browser (Chrome).
Now I will wondering to know if it’s possible to setup speech recognition on local microphone (attached direclty to my hassbian machine).
Would you consider switching to HASS.IO ?
It has a plugin that I believe turns your rpi into a Google Home
# Home Assistant Add-on: Google Assistant SDK
A virtual personal assistant developed by Google.
![Supports aarch64 Architecture][aarch64-shield] ![Supports amd64 Architecture][amd64-shield] ![Supports armhf Architecture][armhf-shield] ![Supports armv7 Architecture][armv7-shield] ![Supports i386 Architecture][i386-shield]
## About
[Google Assistant][google-assistant] is an AI-powered voice assistant that runs on the Raspberry Pi and x86 platforms and interact via the [DialogFlow][dialogflow-integration] integration with Home-Assistant. You can also use [Google Actions][google-actions] to extend its functionality.
You can simply say "Ok Google" following by your command, and Google Assistant will answer your request.
## ℹ️ Integration your mobile or Google/Nest Home with Home Assistant
If you want to integrate your Google Home or mobile phone running Google Assistant, with Home Assistant, then you want the [Google Assistant integration][google-assistant-integration].
[amd64-shield]: https://img.shields.io/badge/amd64-yes-green.svg
[armhf-shield]: https://img.shields.io/badge/armhf-no-red.svg
[armv7-shield]: https://img.shields.io/badge/armv7-yes-green.svg
[dialogflow-integration]: https://www.home-assistant.io/integrations/dialogflow/
This file has been truncated. show original
Fulvi_Igor
(Fulvi Igor)
January 26, 2018, 11:51am
3
I’m coming from HASS.io … too slow automation and webserver on Raspberry Pi3.
Strange, I’ve just moved from HA on a HP Microserver to HASSIO on rpi3 and not noticed a difference.
Have you checked your log for errors ?
Fulvi_Igor
(Fulvi Igor)
January 26, 2018, 12:32pm
5
Same error of timer restting… nothing other… now I’m on i3
