Speed Test and ISP
Hi all.
I would like to request new sensor in speedtest for HA: ISP sensor to monitoring which provider is in use (in case of multiple ISP, for example).
Is it possible?
Many thanks.
Bye.
Enrico
second that… in most cases, what I get from speedtest.org is much higher then what the integration show and this one does not use the same providers too
Please also vote for your own request !!
There is a DNS IP integration:
This will show your public IP which might be enough to extract your ISP.
Otherwise you could try to make a sensor on https://ip-api.com/
