Can anyone think why these are the results I got at speed testing (HASSBIAN)
When I connect a laptop directly to the router, I get great results (it’s the same router that the RPI is connected to
Is the Pi allowed to communicate outside your local network?
Can you ping a host outside your network?
What model Pi?
Is the pi connected via wifi or wired?
s the Pi allowed to communicate outside your local network? - yes
Can you ping a host outside your network? - yes (8.8.8.8)
What model Pi? - RPI3
Is the pi connected via wifi or wired? - WIRED
Im running v 1.32 and speedtest works fine. May want to check the server being used, it may have a connection issue on the other end.
Pi3 or Pi3B+?
PI3
With the laptop through the same server the test goes properly
What if you try to download like a 100mb bin file from some kind of speedtest site? If that is slow too, check the cable connected to the pi and also check what the throughput is at the moment
How do I do it through the pi?
hmmm gives you 2mb/s… You sure you test also a local server with the speedtest tool? Not one in like Asia somewhere while you are in USA or Europe?
Is it possible that your router is blocking traffic to your Pi?
I dno’t think so
I have another compnants like a weather, And they are show the information from the internet
Try pinging an IP/Domain on the web.
The PING works, I checked against 8.8.8.8 and another site
