Speed up Mqtt to Serial to 433 mhz
Hi! I’m looking for a recommendation on how to improve the speed of my code.
I have a ceiling fan with an integrated light that is controlled by a 433 mhz remote. I have tried to run the code directly on an esp8266 and the library times out and crashes (seems to be a part of the code that is blocking and crashes the wifi connection). Also, using the esp8266 or esp32 with ESphome + the remote_reciever library is not an option because this remote is not showing any codes on the remote_reciever output. If outputting raw, there is to much information.
right now I’m using an esp32 serving as a Mqtt to serial transciever, decodes the mqtt messages an it assign a numeric code (from 0 to 20). An arduino uno read the code recieved on serial and sends the code over 433. The code works, the only problem is that there is a 1 to 2 seconds delay between mqtt action (ie using the dashboard button, or pressing a switch) and the fan performing the action itself. How can I speed up the code? (So I can improve WAF)
Arduino code: pastebin url
#include <SoftwareSerial.h>
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
const byte rxPin = 2;
const byte txPin = 3;
// Set up a new SoftwareSerial object
void setup() {
    // Define pin modes for TX and RX
    pinMode(rxPin, INPUT);
    pinMode(txPin, OUTPUT);
    // Set the baud rate for the SoftwareSerial object
    Serial.begin(500000);
    mySwitch.enableTransmit(4);
    mySwitch.setProtocol(10);
void loop() {
  // put your main code here, to run repeatedly:
  String str;
  if (Serial.available() > 0) {
    str = Serial.readString();
  if(str.length()>0){
//    Serial.println(str);
//    int strLength = str.length();
//    int index = str.lastIndexOf("/");
//    Serial.print("index: ");
//    Serial.println(index);
//    String sub = str.substring(str.lastIndexOf("/")+1);
//    Serial.print("sub: ");
//    Serial.println(sub);
//    int value = sub.substring(sub.lastIndexOf("/")+1).toInt();
//    Serial.print("value: ");
//    Serial.println(value);
//    sendcode(value);
    sendcode(str.toInt());
//    if(str.indexOf("light/intensity")>0){
//      light(value);
//    }else if(str.indexOf("light/temperature")>0){
//      temperature(value);
//    }else if(str.indexOf("fan/speed")>0){
//      fanSpeed(value);
int sendcode(int code){
  Serial.print("code ");
  Serial.println(code);
  switch (code){
    case 0:
      ////Serial.println("Apagar luz ");
      mySwitch.send("10011010011010011101111110100000");
     break;
    case 1:
      //Serial.print("Encender luz ");
      //Serial.println(code);
      mySwitch.send("10101010100101011101111110100000");
      break;
    case 2:
      mySwitch.send("10101001100101011101111110100000");
      break;
    case 3:
      mySwitch.send("10100110100101011101111110100000");
      break;
    case 4:
      mySwitch.send("10100101100101011101111110100000");
      break;
    case 5:
      mySwitch.send("10011010100101011101111110100000");
      break;
    case 6:
      mySwitch.send("10011001100101011101111110100000");
     // break;
    case 7:
      mySwitch.send("10010110100101011101111110100000");
      break;
    case 8:
      mySwitch.send("10010101100101011101111110100000");
     // break;
    case 9:
      //Serial.println("Codigo no disponible");
      //mySwitch.send("10011001100101011101111110100000");
      break;
    case 11:
      //Serial.println("2700K");
      mySwitch.send("10011001011010011101111110100000");
      break;
    case 12:
      //Serial.println("4000K");
      mySwitch.send("10010110011010011101111110100000");
      break;
    case 13:
      //Serial.println("6500K");
      mySwitch.send("10010101011010011101111110100000");
     break;
    case 14:
      //Serial.print("velocidad ventilador");
      //Serial.println(code-10-3);
      mySwitch.send("10101001100110011101111110100000");
      break;
    case 15:
      mySwitch.send("10100110100110011101111110100000");
      break;
    case 16:
      mySwitch.send("10100101100110011101111110100000");
      break;
    case 17:
      mySwitch.send("10011010100110011101111110100000");
      break;
     case 18:
      mySwitch.send("10011001100110011101111110100000");
      break;
     case 19:
      mySwitch.send("10010110100110011101111110100000");
     break;
    case 20:
      //Serial.println("Apagar ventilador");
      mySwitch.send("10100101011001011101111110100000");
      break;
  /*if (code==14 or code == 15 or code ==16){
      String fanSpeedString;
      fanSpeedString = String(fanSpeed);
      fanSpeedString.toCharArray(fanSpeedString,fanSpeedString.length()+1);
      mqttClient.publish(fanSpeedString,"sensors/fanSpeed");
void light(int value){
  switch(value){
    case 0:
      break;
    case 1:
      break;
    case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    case 5:
      break;
    case 6:
      break;
    case 7:
      break;
    case 8:
      break;
void temperature(int value){
  switch(value){
    case 2700:
      break;
    case 4000:
      break;
    case 2:
      break;
void fanSpeed(int value){
  switch(value){
    case 0:
      break;
    case 1:
      break;
    case 2:
      break;
    case 3:
      break;
    case 4:
      break;
    case 5:
      break;
    case 6:
      break;
ESPHome Code: pastebin url
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
ota:
  password: "11253e65714b71241d3516a40bbd63d5"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp-To-433 Fallback Hotspot"
    password: "urI1L83WcTKk"
captive_portal:
uart:
  tx_pin: 17
  rx_pin: 16
  baud_rate: 500000
mqtt:
  broker: 192.168.1.71
  username: !secret mqtt_user
  password: !secret mqtt_psw
  birth_message:
    topic: espto433/status
    payload: online
  will_message:
    payload: offline
  on_message:
    - topic: espto433/light/intensity
      then:
        uart.write: !lambda |-
            std::string str = x;
            int y = atoi(str.c_str());
            std::string s;
            if(y==0){
              s="0";
            }else if(y==1){
              s="";
            }else if(y==2){
              s="2";
            }else if(y==3){
              s="3";
            }else if(y==4){
              s="4";
            }else if(y==5){
              s="5";
            }else if(y==6){
              s="6";
            }else if(y==7){
              s="7";
            }else if(y==8){
              s="8";
            std::vector<unsigned char> v(s.begin(), s.end());
            return v;
    - topic: espto433/light/temperature
      then:
            std::string s;
            if(y==2700){
              s="11";
            }else if(y==4000){
              s="12";
            }else if(y==6500){
              s="13";
            return v;
    - topic: espto433/fan/speed
      then:
            std::string s;
            if(y==0){
              s="20";
            }else if(y==1){
              s="14";
            }else if(y==2){
              s="15";
            }else if(y==3){
              s="16";
            }else if(y==4){
              s="17";
            }else if(y==5){
              s="18";
            }else if(y==6){
              s="19";
            return v;
Thanks in advance!
Sounds like a job for openmqttgateway.
After some time tinkering with it open mqtt gateway was a solid option indeed. Thanks.
It is still a bit laggy, but much better than before. Still much faster than looking for the remote
