I feel that the SpeedTest integration is missing a “last updated” sensor to show when the test was last run.
Thanks you!
Thanks you!
Yes, I know. My internet connection is rubbish.
You didn’t vote for your own WTH.
I can see that sensor being useful. In the meantime you can create your own template sensor for this.
template:
- sensor:
- name: "Speedtest Last Update"
unique_id: speedtest_last_update
device_class: timestamp
state: "{{ states.sensor.speedtest_download.last_updated }}"
I just voted! My first time submitting a request.
Thank you for the work around!
It works perfectly! Thank you!!
Yes, what Jason said.
Sorry I didn’t give more details (suddenly realised that I couldn’t remember how I did it ).
If you haven’t found it already, you might be interested in the Speedtest add-on. It doesn’t replace the integration, but it allows you to select the server to be pinged (making for more accuracy) and you can run it as often as you like.
I installed that too! I’m all good with the addon and the yaml example Jason gave me.
