After using HA in docker on my Synology NAS DSM918+ for the last 2 years, I decided to switch to HASSIO inside a VM on the same Synology NAS (Zigbee2mqtt and DSM 7).
Strangely the results of my speedtest integration with HASSIO very slow compare to my previous test done with the same integration in HA inside Docker.
To be sure I run a new speedtest inside a standalone docker on the same NAS and get full speed.
docker run --rm --net=host tianon/speedtest
Latency: 1.13 ms (0.09 ms jitter)
Download: 932.23 Mbps (data used: 419.1 MB)
Upload: 810.03 Mbps (data used: 576.8 MB)
My result with the speedtest integration inside HASSIO is more around 250 Mbps
I tried to run speedtest inside NodeRed in the HASSIO and a get similar results
I run speedtest inside NodeRed in my original installation inside Docker and a test better result (not yet full speed).
Thanks in advance for any help!
