Speedtest integration work flawlessly on “auto-update” mode, no problem there.
It also works perfectly fine if triggered manually via dashboard UI.
However, even though It seems to run every hour, the automation doesn’t produce the intended results and the widget displays “entity is currently unavailable” error.
The same happens for me. The log says “Error fetching speedtestdotnet data: Unable to connect to servers to test latency.”. I have a separate ping test which shows my internet is up all the time so I have no idea why it wouldn’t be able to connect to speedtest. I was thinking of trying to ping the url first as part of the automation.
I have tried adding a scheduled speed test in node-red and it seems to work fine so I will switch to using that. It just needs an inject node with a repeat at the required times and then the call service node - 2 nodes so very simple to set up.
I’m now getting the same problem I had with native automation in that the speedtest service is unavailable. I guess that makes sense since I’m just calling the same service whether using native automation or node red. So I think this is still a problem. Will try calling the service twice, maybe the first fails and the second will work!
Native automation ‘works fine’ if calling the speedtest service twice - with a minute long wait sandwiched between. I still see the first one error in the logs but then the second is fine. Its like its a timing issue whereby it tries to run the test before its resolved the name to an IP but by the time of the second test something has been cached so it works fine.
Having this exact issue. It seems the speedtest service is now removed from the integration. Calling the update entity service twice in a row with a wait in between also doesn’t work.
