Before the 2023.1: Happy New Year of the voice! - Home Assistant release ran the speedtest using an automation. After the release I had to disable the polling for updates to stop it from testing every hour, but I cannot stop it from running a speed test at the startup of HA.
Does someone know how to disable all “self triggered speed tests” ?
This is all I could find and what I disabled. Did I miss something?
If enable polling for updates is disabeld there is no self triggert update and there is no update with the automation running several month fine with homeassistant.update_entity.
So how we can only run a Speedtest to special times and not all the day?
The hourly run is described in the release notes I added in the opening post.
It writes:
The update frequency option has been removed. The default frequency is now 60 minutes. If you like to customize the polling: disable polling update from system options and use the update_entity service in an automation to manually update it at your own custom schedule.
This topic is about the fact that speedtest runs after a restart of HA.
Yes I know, but I do not want to self running every 60 minutes and not after a restart. I use a automation update the entities to run a Speedtest on a special time and do not want more.
I am not able to get my config at the moment, but the docs are helpful too I guess: Iperf3 - Home Assistant
To add the iperf3 sensor to your installation, add the following to your configuration.yaml file. After changing the configuration.yaml file, restart Home Assistant to apply the changes.
