Dear Experts,
I am not able to execute the below attached automation script. Kindly guide me the right approach.
- id: "speedtest restart"
alias: "speedtest restart"
- platform: state
entity_id: sensor.speedtest_download
to: "unavailable"
- delay: "00:05:00"
- service: speedtestdotnet.speedtest
Error : The automation “speedtest_restart” (automation.speedtest_restart ) has an action that calls an unknown service: speedtestdotnet.speedtest .
Regards
Vinay Krishna
koying
(Chris B)
February 15, 2024, 12:26pm
2
Where did you get that such a service existed?
tom_l
February 15, 2024, 12:27pm
3
You can’t just make up services. Where did you see this?
Try this instead:
- service: homeassistant.update_entity
koying
(Chris B)
February 15, 2024, 12:32pm
5
That service was removed 2 years ago.
Better to refer to the documentation:
Is there any way to disable and enable the integration through automation.?
hawksj
(Sam)
February 15, 2024, 1:05pm
7
If you’re just trying to update the speedtest_download sensor, you need to call the homeassistant.update_entity service against the sensor as Tom stated and as is written in the documentation. There shouldn’t be any need to enable or disable the integration. Please explain what you’re trying to do if you think it is necessary to disable the whole integration.
koying
(Chris B)
February 15, 2024, 1:45pm
8
You can disable the “default” polling, if that’s what you want.
It’s the same for all integrations.
