Is possible to add an specific ip for speedtestdonet?
For example my raspbery hassio ip is: 192.168.1.145 but i want to monitorize my server ip 192.168.1.165, is possible?
No. The server_id option is for choosing one of speedtest’s servers only.
You could try the ping sensor. Latency only, no up/dl speeds.
The iperf sensor can be used for this.
You will need a iperf server set up on your server and be aware that the data will be limited to the throughput of your raspberry pi’s connection.
