Hello i have white led ledstrip only, as a driver i have P9813 driver bard connected to my ESP32.
is there a way to alter the config so i only have brighntess on a selectable channel, in my case the green chanel
it works but i have the color wheel within HA, and i only wan’t i brigtness slider to control only the green (white) channel.
below the config from within esphome.
#setup SPI interface
spi:
mosi_pin: GPIO12
clk_pin: GPIO11
#Setup lights
light:
- platform: spi_led_strip
num_leds: 1
data_rate: 1MHz
default_transition_length: 0s
