Hi!
I know there are other threads available that deals with the same problem but I cannot get it to work with those instructions. They are a bit old, possibly something in the hass.io implementation have changed?
I want to divide my automations.yaml into multiple files.
Today I have this line of code in my configuration.yaml and my automations in automations.yaml and it works fine.
According to other posts it should be possible to have one file per automation by creating a folder named automation in my config directory and within the folder add one file for each automation. Instead of the above line of code I would simply add this to configuration.yaml instead
automation: !include dir_merge_list automation
Even if I leave the automation folder empty (to avoid any errors in those files) I can not even get hass.io to boot into the web iterface. If I reverse to the first line it works again.
What am I doing wrong?
Thanks!
