jwillemsen
(Johnny Willemsen)
December 13, 2023, 12:08pm
1
At least the Daikin AC has separate settings for a horizontal and vertical swing and it looks more climate devices do have that. Home Assistant only provides one swing_mode attribute, would be much easier if there is a separate horizontal_swing_mode and vertical_swing_mode as supported feature with accessors/setters.
See for example Vertical direction - Floor heating · Issue #89 · rospogrigio/daikin_residential · GitHub
craig59
(Craig Rayner)
September 26, 2024, 1:43am
2
Agree. The Daikin has both vertical and horizontal swing in the Sensibo App, and the Climate React.
I am able to program swing mode for both independently in climate react:
alias: Loft Climate On Winter Mode
sequence:
- action: sensibo.enable_climate_react
metadata: {}
high_temperature_threshold: 24
low_temperature_threshold: 23
smart_type: temperature
high_temperature_state:
"on": false
low_temperature_state:
"on": true
fanLevel: auto
temperatureUnit: C
targetTemperature: 24
mode: heat
horizontal_swing_mode: auto
swing_mode: auto
entity_id: climate.loft_hvac
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
- action: switch.turn_on
entity_id:
- switch.loft_hvac_climate_react
data: {}
description: Turn on the climate react in the Loft in Winter Mode
mode: single
icon: mdi:home-thermometer
but the UI lacks the ability to set these individually.
jwillemsen
(Johnny Willemsen)
October 27, 2024, 8:59am
3
I am waiting on the HA core/frontend changes to implement this in the daikin_onecta integration, see Support upcoming horizontal/vertical swing modes · Issue #294 · jwillemsen/daikin_onecta · GitHub
